Time counter (20 hours)
Hi
with BS2
How can I make a time counter of 20 hours.
Exemple: I want that when 1 is high for 20 hours, a buzzer turns on.
Thank you
with BS2
Thank you
Note that this doesn't take care of the case where the test input goes off briefly while the Stamp is waiting for a minute to pass. You may need external hardware for that sort of situation. It's possible to use shorter "ticks", but you start running into accuracy problems.
[Something or other about some blasted thing from ehkss-mawss will likely follow.]
Post Edit -- A super low-power CMOS crystal counter/divider, lots of ways to make it happen.
** I'm violating my policy of not making suggestions. I'm back-sliding, must... stop. **
Thank you for your help. I will try the both.
