Position controller KIT #27906 — Parallax Forums
jessicajessica Posts: 8
edited 2010-08-29 17:54 in Robotics
Hi everybody,
I would like to know if it's possible to use the position controller kit from parallax with the 7.2V Motor, Bracket and Wheel Kit.
Thanks a lot for help
  • WhitWhit Posts: 4,191
    @Jessica - you would have to do some adapting. The 7.2 volt motor and wheel kit motors have a shaft extending from each end of the motor. The inside (non whell side) shaft is made for an encoder. I think you could make an adapter for the toothed plastic wheel used on the Position Controller kit. This toothed plastic wheel is designed to work with the 12 Volt motor and wheel kit.
    Encoders are planned for the Stingray (which uses the 7.2 volt motors and wheels). That encoder should work on the motors without an adapter - but it is not avaliable yet. See this link from the Stingray resources thread for some encoders (non-Parallax) others have used for the 7.2 volt motors - Stingray Motor Shaft Encoders - http://forums.parallaxinc.com/forums/default.aspx?f=10&m=415461
    _
    Good luck!
