UV sensor?
Are there any UV sensors or applications that I could use on an near space balloon. I have temp, humidity, and compass sensors. We will be purchasing the GPS sensor and board for logging, but the science dept. wants something with measuring rays. Any ideas?
Bill R.
N5VEI
Bill R.
N5VEI
Also, the TSL230 that Parallax sells has some sensitivity between 300 and 400 nm. It could be used in conjunction with a UV bandpass optical filter. Or you could use two of them, one with a UV blocking filter, and compare their outputs.
http://www.hobby-boards.com/catalog/main_page.php
If I remember correctly, LED outputs can sometimes be somewhat temperature sensitive, so I suppose if they are used as input measurement devices, you might see some temperature dependencies, too, especially at near-space conditions. Keep that in mind so that you can get a meaningful calibration curve for the device. You should probably have a thermal sensor near the UV detector in case sunlight warms it up or it gets really cold in a shadow.
My 2 cents worth.
Parallax has some chapters of a book of his with some useful info; http://www.parallax.com/Portals/0/Downloads/docs/cusapps/NearSpaceCh8-v1.1.pdf
N&V column; http://www.nutsvolts.com/index.php?/magazine/article/led_based_photometer
That looks like an interesting book. What was its title?
thanks,
Mark
