LVDS query
LoopyByteloose
Has anybody worked with this? Apparently the EEEpc transmits the digital to the VGA through a 20 wire cable that uses LVDS (low voltage differential serial). It certainly is new to me, but it has high speed and can handle bandwidth -- maybe optimal for the Propeller.
http://www.national.com/mpf/DS/DS90LV019.html#Overview
Hey!, that's one of the IC's I put together !!
The connections should be pretty straight forward looking at the datasheet. The benefit of using a differential drive is that you are less susceptible to external interference due to common mode signal rejection making for higher speed capabilities than if you were to simple use a straight wire.
http://www.national.com/ds/DS/DS90LV019.pdf
