is there a command for reading a particular bit in a variable in memory?? — Parallax Forums
laser-vectorlaser-vector Posts: 118
edited 2010-08-25 09:04 in Propeller 1
Hi all, this may be a simple question but:
lets say i have a variable named Status
Status is a long that equals %00000001_00000000_00000000_00001111
how would i do a bitwise lookup on bit 24 to see if its a 1 or 0??
thanks
  • HarleyHarley Posts: 997
    edited 2010-08-24 18:17
    @ laser-vector
    How about Bitwise decode '|<' if you are working in Spin?
    Status and |< 24
  • RaymanRayman Posts: 16,390
    edited 2010-08-24 18:27
    another option is to utilize the unimplemented B port registers...
    If you say outb:=status, then you can do:
    if outb[24] then...
  • JonnyMacJonnyMac Posts: 9,819
    edited 2010-08-25 00:02
    bit := (variable >> bit_position) & 1
    edited 2010-08-25 08:48
    Or, if you only care about zero vs. non-zero:
    if (variable & constant(1 << bit_position))
    Similar to Rayman's suggestion of using Port B, if you are not using one or both of the counters, you can use phsa, phsb, frqa, and frqb in the same way as the example he provided.
