which boardto buy for te prop one is $161
Looking to et frther into electonics. One board is $161 the other is $80.
I have made a few circuites using picakebut not sure if i should tackle the $161 board,thouh i am sure it is better.
Any thouhts please ?
and the smaller demo board?
I think perhaps you would do well with The Propeller Education (PE) Kit
instead.
The Demo board is a good starting point for learning to use and program the Propeller. I'd suggest spending an extra $20 for the Starter Kit with a printed manual and free extra book. Both books are great. An electronic version of the manual available free to download and is included with the Propeller Tool (free)
Duane
Holly posted while I was writting this. I personally like the Demo board better as an intro to the Prop but the PE kit is less expensive.
The demo board is a nice to have. If you get some xtals for it, 5, 6, 6.25 Mhz, you've got all the common clocks. A whole lot of code targets the demo board, meaning you can just run stuff. Adding a SD card is easy, because it fits on the little breadboard included.
If dollars are a priority, then you simply need to sort out where you want to start. If in doubt about building up stuff, get the demo board, because you can do a lot with it, and it's a nice size.
If building stuff up is no problem, the PE kit is a great deal, and I would also recommend a proto board. Use the PE kit to build up the various interfaces you want, then take a proto board, and solder them together, forming "your" ideal board to go forward with.
I was thinkin of buying the propkit item 32305
2.prorammin the prop item 32316
3. professional dev board
4. propdev board item 32100
Do you think this order wold be sfficient. I dont really want to go back to all the starter kits mostly because they se basic I think?
A penny for your thoughts ,)
Humanoido
You didn't include an item number for the Professional Development Board. There are two. Item 32111 has a place to plug in a 40 pin DIP Propeller chip (not included). So if you get one make sure you also puchase at least one DIP Prop. Item 32305 comes with a DIP Prop so you'll be okay with it.
The other Professional Development Board item 28138 does not have a socket for a Prop. You could still plug one into the bread board section but I'd recommend the Propeller PDB if you what to use a Prop.
Item 32100 is great but I still think you'd be much better off getting item 910-32300 . The included books are well worth the extra $20.
As Humanoido mentions, proto boards are also great. I have lots I use all the time.
Duane
The demo board (32100) was just on sale a few days ago. There has been a lot of Propeller stuff on sale for the daily deals lately, but I haven't seen the 910-32300 kit yet, so it may be coming up soon. It has been on sale in the past for $20 less than normal.
I have one which I use a lot when it's not loaned out. I think the Propeller is so cool, I've tried to get others interested by lending my Demo Board and the Propeller books I own. I thought it would be nice to have a couple of extra Demo Boards for my own use and as part of my lending library. I decided against it. Good thing since the Hydra went on sale a week later and I could use the money I "saved" not buying Demo Boards on the Hydra. It's nice to remember I have said "no" to a Propeller board on sale.
I have lots of Proto Boards to lend so I still hope to make some converts to the Propeller hobby.
Duane
I was realy keenon getting the huge breadboard but i yjought it may be too much at this polnt!
Thanks for the kit suggeston , i was abot to order it from didtibutor in nre south wales !
When I am better st all thid i will otrder yjr large bread board
Can I buy development boards from snothrer supplier to rduce my cost ?
Thabk you for lifting to mr
Mike Lynch
