PWM LED control
I am using BS2 to dim an LED strip that uses 12V with maximum of 14W (about 1.1A). I have used the PWM on the BS2 quite a bit but wanted to know the best method to have the signal from the BS2 controlling the light intensity. I was thinking of using a Darlington Transistor like the TIP120 but wanted some feedback from the experts.
much appreciated.
Al
much appreciated.
Al
and are you using the PWM command or Pulseout . I have found the latter works better .
http://www.flickr.com/photos/peterthethinker/4794741329/in/set-72157623214411145/
' {$STAMP BS2} ' {$PBASIC 2.5} Part1 VAR WORD Part2 VAR WORD Part3 VAR WORD Part4 VAR WORD DO 'READ POT HIGH 1 PAUSE 1 RCTIME 1,1, Part1 'DO math Part2 = Part1 + 45 Part3 = Part2 * 106 Part4 = Part3 - 4876 'DO out PULSOUT 10 , Part4 DEBUG DEC part4 ,CR LOOP
