Need help finding a good(cheap) SATA/IDE to usb cable
Hey, although my expertise( And probably most everybody on this board) lies in micro controller programming i occasionally try to venture into PC repair/ Upgrading. Here is the story... My sister's computer recently died leaving all of her data stuck on the hard drive. One day it was working and then it just wouldn't boot anymore. I have used the BIOS setup utility to check some of the various parts and the RAM checked out and so did the hard drive. My sister just needs to get some data off of the drive and i heard that a SATA/ IDE to USB adapter would do the trick. Would this work?
http://www.amazon.com/Serial-ATA-Adapter-Converter-Backup/dp/B001Q4Z5KY
Mind Fluxbox is not Win7 or (Beryl
On My mac systems I just use the Firewire disk mode
"To use BitTorrent, Download it, and visit the Knoppix BitTorrent Tracker, and click the "DL" link next to the image you want to download ( -EN or -DE ). Save that file, then run btdownloadgui KNOPPIX-"
Puppy Linux, Knoppix, and many other small Linux_s still are very useful for determining it the machines hardware is intact. If a virus in Windows downed the machine, these will load independently of the hard disk
(intially only load in RAM).
But if the hardware has died, you may need a Sata to IDE adapter rather than a Sata to USB. I have for the Sata to USB, with a separate power supply.....and Clonezilla.
For a temporary power supply, you could use an internal computer's power supply to the hard drive if you want to save money and don't need a case for the old drive.
Now about Linux.. I don't really like it so far. A lot of the concepts are very abstract and not very user friendly. Like it is so hard trying to figure out how to install programs. There is no "Install Button" or anything, instead you have to literally prompt the machine to run, by typing in the file manually. While i like a challenge(And open source software), i can see why Windows and Mac OS's have the upper hand. Or maybe it is just the version of Linux that i am using....
Linux is like a car . you can lift it lower it install NOS and paint it too.
and like cars some want a VW bug . light fast ( DSL knoppix puppy)
fedora and ubunto are like the honda civic of distros . there easy to use and are popular .
so on and so forth ..
I have used so far a dozen or more Distros .
I just got in to CENTOS cause its more redhat like and uinlike fedora its not released every 6 months it seams .
1. It has vast free software utilities that were written long ago for Unix.
2. It can be made very small by getting rid of the Graphic User Interface.
3. It can run independently of the OS installed on a hard disk via a "LiveCD"
4. Programing quick and dirty solutions for yourself don't require C, C++, or whatever - you can use BASH, or Python, or a lot of very handy languages.
5. When you really think Windows is corrupted, that "LiveCD" can verify that you do indeed have a software problem because the Linux will run correctly - and can even take a look at the integrity of the hard disk FOR FREE.
But, it does come with a learning curve. Do some reading.
Not all the new books are good. I picked up a copy of a fundamental UNIX text in order to really understand what it was all about.
Life with computers is so much easier when you can sort out the blame between hardware and software. I suppose any 2nd OS would do the job, but Linux is the free one. Even a 'LiveCD" of Ubuntu Linux will tell you if your machine is dead. You don't have to use a small Linux.
This obviously only requires standard serial cables & power connectors, no USB converter needed.
I guess I see a Ton of them here In Iowa . that and Pontiac.
DSL on a P4 is like a Hemi on a lawn tractor ..
there are a few hangups with WiFi cards and some brands of printers .
but I would say most of HW compatibility issues can be solved with some pre buying research ..
Every OS has is uses .
Linux is not a good choice to edit a Hollywood movie on nor a new album . AV intergration is not its bag . But Liunx is CHEAP and its Very stable for what it is . it good for a second computer . if you want to spend the time almost anything is possible with linux .
and its rewarding to own .
OSX has its downs too. it runs legally on only very pricey ( IMHO good) hardware so its not for everyone .
Mind apple has a Very nice set of laptops . 10H batts backlit KBs and BT in every model .
things I expect in the computer world come stock on a mac . and the Mac mini is one VERY nice dorm SOHO computer . and it run WIN native nothing to lose ..
and yes apples HW stats are by number less then a PC( windows) of the same price BUT
cause of the Less fat OS they can Still Be fast In real life ( as long as it runs as fast to ME while I use it I dont care if it ran on a 386DX) .
Windows is a OK all around OS but its IMHO overweight , it eats ram/CPUcycles for dinner and needs constant attention to keep running ..
Ironicly the reason I went to Linux a second time was to watch YT vids as my OS9 Mac could not . and I was not about to dump $7K
In editing SW for OS9 to use OS X ( and no FCP I had was NOT classic compatable ) .. I still Love how simple and light OS9 was .
I went from OS9 PPC to OSX x86 in less then 7 months . Gahhh SW was expensive but it had to be done . the one thing I did not re buy was adobe stuff . VIVA GIMP . !
Kevin is right Virtual Box is amazing . lots of the network students here use it.
Me ,I have not had a need..
My main computer is my Mac Mini .. If this thing dies I will be in deep poo so I don't touch the INT HD on it ..I run EXT.. At one time I Firewire booted XP on a Old 80G HD . I did this as it kept the HW separate to the point that if XP decided to cause issues I can Pull its plug .If I ever want to be back to normal Mac with my life on it I can just unplug the Ext HD and reboot .
I generally go with the crowd and like Ubuntu, but Linux Mint has rocketed from about #100 to #3 in popularity over the past year or so.
There is a web site that evaluates all this, called Distrowatch.com
I am also a big fan of Puppy Linux. But that world changes rapidly too.
I dislike Fedora, only because they want you to buy video driver software from M$ (because they are American based) rather than use clones. But it is a good product.
