Pulse sensor
Has anyone made use of the Parallax Piezo Film Vibra Tab Mass LTDO sensor? It appears to be rated much higher than my needs, to sense a human pulse., at a 25 lb rating.
Maybe an IR LED/phototransistor combo might work? Anything else? I'd imagine one or more OpAmps would be needed to scale the sensor output to Prop levels for sigma-delta A/D conversion. I'm welcome to all ideas here. An area I've not worked in before. I'm Googling for info on this area too.
Using a D/A to simulate a pulse; A/D is seeing raw D/A output without any filtering in this pic.
You might be able to do something similar with a presure sensor. I agree a piezo film isn't an appropriate sensor here. I've played with a SCP1000 a little myself. I know there an object for it in the OBEX. A BMP085 costs less. I'm not sure which would be best for this application. I wonder how important a cuff is. I can't think of how else (besides a cuff) to monitor the pulse pressure. I'm very interested in what you come up with. I hope you share your results.
Duane
Edit: I think the blood presure device was called DynaPulse.
Duane
@Leon, I wasn't thinking of contacts, but just maybe a pressure or IR detector scheme. I don't know enough about the quality of the signal if it weren't contact-connected.
Somewhere years ago I recall an IR approach, with IR LED at an angle to the IR photo-transistor as pickup; two holes drilled about 60° angle in a block of metal/wood/plastic, with the LED and photo-transistor fit in the holes. The variations in the vein just under the wrist skin supposedly produced a signal. And I don't even recall if it were displayed or just squared up and measured 1/t for beats per minute. A really slow signal compared to the Prop's 80 MHz clock. When I heard of 3.5" color LCD Rayman had for sale, that began my design on the display end first. Now for the front, sensor portion.
