No Usable Serial Ports Found !
Hello fellows,
I am having problem with my dive into BASIC STAMP Editor. I followed the instructions to the letter one good hour to read just the getting started.
My laptop has no serial ports.
I bought the expensive Staples serial to usb adapter to connect the HomeWork Board. When I open the Editor and hit Identify under the Run sub-menu I get "No Usable Serial Ports Found !"
I have spent 2 days on this and I feel like crying. Please help.
Gudunov
Gudunov
It's important that you NOT use the default Windows USB driver. If you can find a specific USB driver for the Staples device, try installing that before you give up on that adapter.
However, the Device Type is not detected even though LOOPBACK and ECHO have YES in their respective columns below.
I ran thorugh the Help Files again to tweak the COMM port properties. Nothing is happening!
I am frustrated to now to know that PARALLAX makes its own Serial Port to USB adapter. Why can't they just bundle it with the kit ? The $46 I spent on this Staples USB adapter alone could have fetched me 3 of the Parallax USB adapters, and got me through the book 72 hours ago !
"Echo" means that there's a connection between the transmit line from the PC and the receive line back to the PC so any characters sent from the PC are echoed back to the PC. This is shown in the internal schematics for the RS232 interface on the Stamp module. Both schematics are in the Stamp Reference Manual (page 28) and the Stamp Editor help files.
In order for the Stamp to be identified by the Stamp Editor, the DTR (Data Terminal Ready) signal has to be connected to the ATN (Attention or Reset) line of the Stamp module using two capacitors as shown in the Manual's schematic. The Stamp Editor uses DTR to force the Stamp to reset, then sends a specific message to the Stamp which causes the Stamp to identify itself. The Stamp has to be powered and operating for this to work.
Kind regards
Erik
FTDI USB Drivers
But for some reason, the reset button fell apart and the green Running light is off now!
I wondered what was going on! Anyway, I have to run for a Bible Class in a few.
Wish me luck with my BASIC STAMP experience!
