Micro Dual Serial Motor Controller — Parallax Forums
logan996logan996 Posts: 281
edited 2010-08-22 07:45 in Propeller 1
Hi all, i bought the MDSMC right when i bought the prop demo board and i was looking at using it for the prop it looks like it would be great on the prop demo board, i tried to use it on my bs2 and it just got hot and didnt work (did i break it? it didnt smell shorted out). so how can i make it work on the prop, i only know how to blink LED's so far and well im learning but slowly, i REALLY dont want $24 (more like $30 with shipping) to go to waste, so are there any objects in the OBEX that work for this? will it even work with the prop? (MDSMC link to make things faster http://www.parallax.com/Store/Accessories/MotorServos/tabid/163/CategoryID/57/List/0/SortField/0/Level/a/ProductID/491/Default.aspx )
    edited 2010-08-22 06:12
    The PDF states Logic Supply: 2.5 - 5.5 V (pg 2 of 12).
    Check your wiring, re-check it, then check it again.
    If you stuffed it, Uncle Ken will FedEx another to you right away.
    Post Edit -- That PDF is chock full of bold, red text. Junk like, "Warning", "Important Note" and the like which, apparently, they take seriously. Curious.
  • TimmooreTimmoore Posts: 1,031
    edited 2010-08-22 06:37
    I have used this motor controller with the prop and its pretty straight forward. I did manage to fry one of the motor controllers when the ground disconnected when power was connected.
  • logan996logan996 Posts: 281
    edited 2010-08-22 06:54
    PJ Allen what do you mean by "Uncle Ken will FedEx another to you right away" ? and i did wire it up right, i dont know why it didnt work. Ill get some new motors from RS and try again.
  • JonnyMacJonnyMac Posts: 9,843
    edited 2010-08-22 06:58
    If you're just blinking LEDs you may want to wait a little while before tackling a motor controller. I don't know that there are an objects for this (doubt it), but that's okay as it's a very simple device.
    I've attached a shell program (which has code that could form an object) that should get you going -- once you're comfortable connecting the motor controller to the Propeller.
    edited 2010-08-22 07:07
    Thanks JM!
    edited 2010-08-22 07:16
    What do you mean by what do I mean?
    You did everything right and nothing wrong. Got it.
    Post Edit -- I'm bad and you're good. That's why it got hot and "doesn't work." Why should it be any different with a "Prop"?
    Take a look at this thread http://forums.parallax.com/showthread.php?t=115237 it discusses this controller and has some code for it.
