clock pulse for the MC14489
I'm setting up a little spin code to send a four digit number to subject chip. The data sheet indicates that for my 5 volt Vdd I can send it a frequency from DC to 4.0 MHz. I don't really need extreme speed, I just want to have the minimum of timing problems. Obviously I must set up a counter to an output pin that will run slower than the Prop clock. Any rules of thumb out there.
Have a look at the Synth.spin object which is available in the PropellerTool library.
