Can I do this? — Parallax Forums
Can I do this?
KyeKye Posts: 2,200
edited 2010-08-20 17:45 in Propeller 1
I need to do very high speed 8 bit parallel input.
I want to do (wrbyte ina, phsa)... and have phsa increment in tune to a clock.
However, I believe I cannot use ina as a destination. So what will happen?
  • ke4pjwke4pjw Posts: 1,313
    edited 2010-08-19 10:20
    Kye wrote: »
    Depends on how you have your parallel inputs. I have done it this way before.....
    mov      rxdata, ina             ' Read pins set for input
    shr       rxdata, datapin       ' Shift data so that the LSB corresponds with D0
    wrbyte  rxdata,t2               ' Write byte from the rxdata into the address located at t2's value
  • jazzedjazzed Posts: 11,803
    edited 2010-08-19 10:25
    Kye wrote: »
    The instruction (if compilable) would probably write the ina "shadow register" value to the address.
  • KyeKye Posts: 2,200
    edited 2010-08-19 10:39
    And that won't be ina right? Shame...
    edited 2010-08-19 12:02
    Ah, the phsa counter. Couldn't you just trim ina with an intermediate variable and mov it to phsa?
    edited 2010-08-19 13:04
    I need it to go to main memory. I'm doing video capture at high speeds.
    edited 2010-08-19 13:14
    (This is a learning experience for me, so please forgive me if my question is ignorant.)
    Aren't the phsa and phsb counters directly readable and writable from each cog? It appears so to me, according to page 285 of the manual. I have no experience with those counters, so tell me if I am just being ignorant. :)
    edited 2010-08-19 13:48
    ke4pjw wrote: »
    Yes, they are and can be used as an index for wrbyte data, phsa for example and Kye is probably doing something like that.
    You can set up something like this code fragment to read pins and send data to a buffer.
    mov ctra, _nco
    mov frqa, _200ns
    mov phsa, hubptr
    :loop
    mov data, ina
    wrbyte data, phsa
    djnz count,#:loop
    There are optimizations for short bursts or specific behaviors on P0-8.
    Cheers.
    --Steve
    BIG Caveat! I knew there was a problem but forgot what it was:) As a good friend reminds me, this would write a byte to every fourth address because PHSA increments every clock tick regardless of FRQA. So any data read would use 4x memory space and would have to be reassembled into a contiguous stream.
    edited 2010-08-19 13:56
    Oh wow! OK, I get it. (I think) So you use the phsa counter as an index of addresses in main memory. This provides a very quick method of incrementing the pointer at a specific point in time, correct?
    edited 2010-08-19 13:59
    Yep. That's right.
  • Jack BuffingtonJack Buffington Posts: 115
    edited 2010-08-20 07:56
    That's pretty clever using phsa. An indirect register would be awesome...
    What is the source of the video that you are trying to capture? I worked on a project a few months ago where I was capturing from a 640x480x60Hz VGA signal. I couldn't capture the whole signal because of RAM issues and the 496 long limitation but if I recall correctly, I could capture three sections of video per scan line totaling about 80 pixels per line. My application required that each scan line could have a different capturable area so that took up a lot of code space but if you had an always defined region, you could capture more pixels.
    I needed to capture every pixel in the regions that I was capturing so what I ended up doing was making two chunks of code. The first grabbed the pixels and stored them in COG RAM in successive locations. I'm already fuzzy on the pneumonics of parallax assembly after not using it for a few months but that code looked roughly like this:
    mov storeLocation+0,ina
    mov storeLocation+1,ina
    mov storeLocation+2,ina
    The other chunk of code wrote them to HUB RAM in the proper location:
    wrword hubLocation, storeLocation+0
    add hubLocaion, #2
    wrword hubLocation, storeLocation+1
    add hubLocation, #2
    The main flow of the program was made possible through self-modifying code so I would be backing up the mov instruction from the first section and replacing it with a jump back to the main routine at the point that I needed to stop capturing. The instruction would then be restored. The second routine would simply have the add instruction replaced with the new hub address that was needed. At the end of the scan line, it would restore that location too.
    edited 2010-08-20 10:47
    I'm capturing data from an ominvision camera. There's a pixel clock so I have to lock onto the clock and sample the I/O lines after that.
    edited 2010-08-20 11:31
    If I remember right,
    Linus Akesson used 8 IO-Ports for fast intercog-communication in the turbulence demo.
    I did not analyse this in detail. But maybe his code gives some new ideas.
    best regards
    Stefan
    edited 2010-08-20 16:13
    The prop diagram for cog interaction via the hub and ram, would be slower than two cogs talking to each other directly using pins, if they are running code that uses cog ram only. The diagram shows that pin access does not go through the hub.
    Quote from the manual
    "After boot up, any I/O pins can be used by any cogs at any time since I/O pins are one of the common resources. It is up to the application developer to ensure that no two cogs try to use the same I/O pin for conflicting purposes during run-time."
    Kye wrote: »
    What about using good old 4c4007 (data sheet it). 1Meg x 4 dram.
    I would make an entire prop be a dram controller.
    Using two of these dram chips would give you a 8 bit bus. After the first dram chip, the addressing/read/write is parallel-able.
    8 bit bus 1 meg. using 2 chips from a edo 72 pin simm.
    800 x 794 - 84K
    edited 2010-08-20 16:23
    jazzed wrote: »
    Is this the reason the font characters are interleaved in the ROMs memory?
    edited 2010-08-20 17:05
    Kye wrote: »
    See attached pdf schematic.
    edited 2010-08-20 17:28
    Nice but, I don't want to use external componets and I don't need to store all the data I input. Only a small bit of it.
    ke4pjw wrote: »
    Fonts are interleaved so you can use half a character if you like for making 3D buttons.
