dummy question — Parallax Forums
dummy question
10gigbill10gigbill Posts: 79
edited 2010-08-18 18:17 in Propeller 1
led blink program. I want the pin to stay high when it finishes.
what did i forget?
thanks..
Bill
  • AJMAJM Posts: 171
    edited 2010-08-18 17:02
    Hi Bill
    Simply end your program with a 'repeat' and you will loop forever.
  • 10gigbill10gigbill Posts: 79
    edited 2010-08-18 17:29
    Thanks AJM:
    that did the trick... dose that mean the chip goes to sleep if it is
    not executing a program? turns off all it's ports..?
    Bill
    Yes. Whenever a cog exits, it performs a stop instruction which turns off the cog's clock and clears the cog's I/O registers which sets the I/O mode of its I/O pins to input. Remember that if another cog is using the I/O pins as outputs, that takes precedence.
