ping))) behavior above the limit of 3m
Hi!
I would like to know which is the exact output that ultrasonic sensor ping))) gives in echo pin when the distance of the target is longer than 3 meters,which is the high limit according to datasheets,(f.e.4,5,10 OR 1000 meters!)???
And how can i find such detailed information?(data sheets don't help
Thank you for the answer! I'm a litle new so sorry for these simple questions but it is very important for i'm doing my thesis these days!!
So if i understand well if the distance of the target is so big that the ultrasonic sound didn't come back, then the sensor will give to the echo pin a TTL pulse with 18.5ms duration. (which means that the distance is 18.5ms*(343/2)=3.17m)
343=sound speed
Thank you again!
Thank you again for your help Mike Green very much!:D
If the distance is less than 2cm then the echo will be 115us and will not go down to 115us OR the ultrasonic sound will lost to the side (so will not come back) so the echo will be 18.5ms (the maximum limit)??
As far as summer goes, same distance to target as above, but noticeable inconsistencies with how well the air transmitted the jet engine whine -as if someone were varying a tonal control at the source. From my observations, it is clear to me that trying to measure great distances with ultrasonic waves depends largely on the current properties of the air between your ultrasonic sensor and the target object & the targets surface acoustical properties -smooth, hard surfaces reflect a cleaner, sharper acoustic image than a coarse &/or soft surface.
The hotter the air mass, the less density -has a natural tendency to roll-off higher frequencies vs distance- also precip or humidity compounds this effect further by acting as an effective acoustic damper. In my opinion, ultrasonic is not a viable solution for med-long range measurements due to too many variables having wide spread effect on the measurement.
Of course the best is to experiment with this although i' m making a simple parking sonar and I hope not to have problems with the air - temperature characteristics!!
