433 MHz RF Transceiver — Parallax Forums
Brian BBrian B Posts: 31
edited 2010-08-27 13:49 in Learn with BlocklyProp
I was wonder the average distance of the 433 MHz RF Transceiver
  • KARIM102KARIM102 Posts: 75
    edited 2010-08-27 03:11
    it is line of sign rang
    edited 2010-08-27 04:27
    "line of sight range" (I hate typos!)
  • MoskogMoskog Posts: 554
    edited 2010-08-27 04:51
    Line of sight range up to 250 feet (depending on operating conditions)
    Using external antennas I have made transmissions up to one kilometer or so. (Thats with the older RF-transmitter and receiver, 27980 and 27981)
    With beam antennas probably even better range as long as line of sight.
  • Mark KiblerMark Kibler Posts: 546
    edited 2010-08-27 11:45
    Brian B wrote: »
    Depends on the signal strength. Yes, it is line-of-sight. You can get 5 miles or so on a straight line signal. Dee www.bigredbee.com
    See or Parallax forum at "Stamps in Class"
    > Project ARLISS
    Mark
    Mark, I'm sure you are right.
    When Brian B talks about the 433 MHz RF Transceiver I supposed he meant the Parallax 433 MHz RF Transceiver, item 27982.
    My reply was based on that specific tranceiver and according to the PDF documentation.
