FTDI and COM port descriptions
If you are like me, you have many devices using FTDI chips e.g. Parallax USB2SER, USB to Serial RS232 adapter, Propeller USB Protoboard, USB oscilloscope, etc etc.
The Windows XP System "Tray Safely Remove Hardware" tool usually shows them all as "USB Serial converter" but does not uniquely define them.
If you are comfortable using the Registry Editor, you can modify the DeviceDesc key for each FTDI device to give them unique names which appear in the Safely Remove Hardware tool.
These keys are found under:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\USB\Vid_0403&Pid_6001
For example, the following reg file shows my Oscilloscope and Propeller Demo Board keys
It is also difficult to keep track of COM ports, so I wrote a HTML application which lists port information pulled from the registry. The devices do not have to be attached to appear in the list.
You may find this stuff useful if you run Windows XP
The attached zip file contains the HTML application (EnumPorts.hta).
USE THIS INFORMATION/HTA FILE AT YOUR OWN RISK
I have no idea whether any of this works under VISTA or Windows 7
Windows Registry Editor Version 5.00 [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\USB\Vid_0403&Pid_6001\5&97be1ee&0&2] "DeviceDesc"="USB Oscilloscope" [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\USB\Vid_0403&Pid_6001\A2002Yej] "DeviceDesc"="Propeller Demo Board"
to UART bridge, Prolific USB-to-Serial and othder Com parts on board, so it's really helping me.
Thank you very much for your work.
Thanks! Good to know.
Do both the EnumPorts.hta and the registry DeviceDesc changes work?
This link may be the answer to updating the registry (if you want to do so):
http://windows7themes.net/windows-7-registry-changes.html
