fastest way to communicate with a pc. — Parallax Forums
DXCDXC Posts: 33
edited 2010-08-16 10:53 in Propeller 1
Hello all,
I am working on work on a big test machine.
As test will hebben on products they will have to go fast,time is money.
Setup is:
- PC sending commands.
- relay switch box controlled with a prop.
Which connection would be the best, just the USB-FT232, ethernet....?
gr,
  • KyeKye Posts: 2,200
    edited 2010-08-13 12:43
    The USB FTDI connection can hit up to 2Mbs.
    If your just controlling relay's then I wouldn't even worry about speed.
  • LeonLeon Posts: 7,620
    edited 2010-08-13 13:05
    High-speed USB with a Vinculum chip is 480 Mb/s, but the Propeller won't be able to keep up.
  • DXCDXC Posts: 33
    edited 2010-08-14 00:12
    Thnx for the reply.
    Speed is indeed not the main factor but ethernet looks nice to have, Im going to put a ENC28J60 in the schematics, and use the prop + ft232 for the time being.
    Kye,
    How can you have speeds of 2mb/s with a ft232 and pc?
    The pc max setting on com ports are 110kB/s or how do I set my com ports?
    Or do I have to use another ft232 chip like?
    gr,
  • jmgjmg Posts: 15,200
    edited 2010-08-15 12:39
    DXC wrote: »
    Thnx for the reply.
    Why not target the FT2232H ?
    Only slightly more expensive than the cheapest one, and you get a 480M core,
    so can get > 10MBytes/s
    These have FIFO, SPI, JTAG modes, so you can choose speeds.
  • ke4pjwke4pjw Posts: 1,324
    edited 2010-08-16 09:03
    DXC wrote: »
    Hello all,
    Setup is:
    gr,
    The fastest I have been able to achieve is with the FTDI FT245. Mouser sells the breakout board.
    3Mbits/second with the virtual com port. I imagine you can go faster using using the D2XX drivers. They go to 10Mbits/second.
    See my sig for the FullDuplexParallel object for use with the FT245.
    PS- You will need 12 data lines open on the prop.
  • FredBlaisFredBlais Posts: 389
    edited 2010-08-16 09:58
    ke4pjw wrote: »
    Does it still use a virtual com port? I think the problem might be on the computer side, it always try to buffer data before we can access it.
    BTW, it's fascinating how my thread name (that I started this month) and this one are similar
    FredBlais wrote: »
    Yes, you can use the VCP driver. The 3Mbit and 10Mbit limits are limitations of the FTDI chip and the driver used (VCP and D2XX respectively). I have not seen any serial methods that can achieve speeds > 512Kbits, with 100% reliability. I have been able to pump 3Mbps through to the prop with the VCP driver and this parallel method. I have not performance tested the D2XX driver, so I don't know what the upper bounds is for my object. As best I can tell, this method is as fast as it gets with the prop.
