I2c memory
I am trying to write and read from the on board 24LC256.
Kwabena W. Agyeman wrote "I2C Electrically Erasable Programmable Read Only Memory Engine" from OBX. It looks so simple to use. I set up a simple project to test writing to the chip.
Depending on the state of a push button pin 11, I am trying to write the stat to the memory.
Then, when I reboot I would like to see via pin27 or pin15 the written previous state.
I use an audio conformation of a (high freq) set of beeps for a "1"state (push button up) and a set of bonks(lower freq) for a "0" state 9push button down), to prove the read state of the pin, while I power down.
When I apostrophe out the write command in PUB WRITEtest {'ROM.writeByte($7000, 0)} the beeping or bonking goes along with the input pin. When I make the command line active the audio generation stops, and moreover, gives erratic tone generation if I wait long enough... so think there is some kind of crashing going on in memory.
I would appreciate help on this a lot. Coding follows:
' TESTING WRITING TO EEPROM MEMORY
CON
_clkmode = xtal1 + pll16x ' Feedback and PLL multiplier
_xinfreq = 5_000_000 ' External oscillator = 5 MHz
BEEPpin =9 ' AUDIO CONFORMATION INJECTION PIN
OBJ
ROM:"I2C_ROMEngine"
VAR
LONG STACK [100] ' STACK
byte EOMhistory ' history read variabel
byte GOODbeep
byte GOODbonk ' Audio conformation variables
byte BEEP
PUB START 'START COGS TURNING
DIRA[BEEPpin]~~
DIRA[27]~~
DIRA[15]~~
COGNEW (WRITEtest(0), @STACK[20])
COGNEW (BEEPMODULE(0),@STACK[40])
EOMhistory:=ROM.readByte($7000) '***I2C READ BYTE TEST****
if EOMhistory==1
outa[27]:=1 'Read history byte from EEPROM; light app LED
elseif EOMhistory==0
outa[15]:=1
PUB WRITEtest(writeVAR) '***I2C WRIE BYTE TEST****
repeat
if INA[11] ==1
GOODbeep:=1
'ROM.writeByte($7000, 0) 'Depending on STATE of pushbutton write a "0" or "1"
' to EEPROM
elseif INA[11]==0
GOODbonk:=1
' ROM.writeByte($7000, 1)
WAITCNT(CLKFREQ+CNT) 'Wait a little bit. Then do it again
PUB BEEPMODULE (BEEPVAR1) ' ***HIGH/LOW AUDIO GENERATION MODULE***
DIRA[BEEPpin]~~ ' Turn on direction rigister for beep pin
Repeat ' Loop for a long time
Repeat while GOODbeep==1 ' Do this loop if the GOODbeep variable has
' been set to a 1
REPEAT 3 ' Do the same thing 3 times
WAITCNT(CLKFREQ/18+CNT) ' Give a short duration between
'beeps (1/18 second)
REPEAT BEEP FROM 1 TO 100 ' Do this loop 99 times
!OUTA[BEEPpin] ' Cycle pin
waitcnt(clkfreq/1000+cnt) ' Wait 1/1000 of a second
OUTA[BEEPpin]:=0 ' Set BEEPpin to off state
GOODbeep:=0 'Reset the GOODbeep flag to zero when done.
'Return to top of loop and wiat for flag to set.
repeat while GOODbonk==1
WAITCNT(CLKFREQ/18+CNT) ' Give a short duration between beeps (1/18 second)
REPEAT BEEP FROM 1 TO 38 ' Do this loop 50 times
waitcnt(clkfreq/400+cnt) ' Wait 1/400 of a second
GOODbonk:=0
CON
OBJ
ROM:"I2C_ROMEngine"
VAR
byte GOODbeep
byte BEEP
DIRA[BEEPpin]~~
DIRA[27]~~
DIRA[15]~~
if EOMhistory==1
outa[15]:=1
repeat
if INA[11] ==1
GOODbeep:=1
' to EEPROM
elseif INA[11]==0
GOODbonk:=1
' been set to a 1
GOODbonk:=0
It'll preserve the tabs and spacing, but you might have to re-paste it from your Spin editor.
OBC
CON _clkmode = xtal1 + pll16x ' Feedback and PLL multiplier _xinfreq = 5_000_000 ' External oscillator = 5 MHz BEEPpin =9 ' AUDIO CONFORMATION INJECTION PIN OBJ ROM:"I2C_ROMEngine" VAR LONG STACK [100] ' STACK byte EOMhistory ' history read variabel byte GOODbeep byte GOODbonk ' Audio conformation variables byte BEEP PUB START 'START COGS TURNING DIRA[BEEPpin]~~ DIRA[27]~~ DIRA[15]~~ COGNEW (WRITEtest(0), @STACK[20]) COGNEW (BEEPMODULE(0),@STACK[40]) EOMhistory:=ROM.readByte($7000) '***I2C READ BYTE TEST**** if EOMhistory==1 outa[27]:=1 'Read history byte from EEPROM; light app LED elseif EOMhistory==0 outa[15]:=1 PUB WRITEtest(writeVAR) '***I2C WRIE BYTE TEST**** repeat if INA[11] ==1 GOODbeep:=1 'ROM.writeByte($7000, 0) 'Depending on STATE of pushbutton write a "0" or "1" to EEPROM elseif INA[11]==0 GOODbonk:=1 ' ROM.writeByte($7000, 1) WAITCNT(CLKFREQ+CNT) 'Wait a little bit. Then do it again PUB BEEPMODULE (BEEPVAR1) ' ***HIGH/LOW AUDIO GENERATION MODULE*** DIRA[BEEPpin]~~ ' Turn on direction rigister for beep pin Repeat ' Loop for a long time Repeat while GOODbeep==1 ' Do this loop if the GOODbeep variable has been set to a 1 REPEAT 3 ' Do the same thing 3 times WAITCNT(CLKFREQ/18+CNT) ' Give a short duration between beeps (1/18 second) REPEAT BEEP FROM 1 TO 100 ' Do this loop 99 times !OUTA[BEEPpin] ' Cycle pin waitcnt(clkfreq/1000+cnt) ' Wait 1/1000 of a second OUTA[BEEPpin]:=0 ' Set BEEPpin to off state GOODbeep:=0 'Reset the GOODbeep flag to zero when done. Return to top of loop and wiat for flag to set. repeat while GOODbonk==1 REPEAT 3 ' Do the same thing 3 times WAITCNT(CLKFREQ/18+CNT) ' Give a short duration between beeps (1/18 second) REPEAT BEEP FROM 1 TO 38 ' Do this loop 50 times !OUTA[BEEPpin] ' Cycle pin waitcnt(clkfreq/400+cnt) ' Wait 1/400 of a second OUTA[BEEPpin]:=0 ' Set BEEPpin to off state GOODbonk:=0ROMEngineStart(dataPinNumber, clockPinNumber, lockNumberToUse)
function before using the I2C code to make sure everything is ready to go. You'll probably want the arguments...
ROMEngineStart(29, 28, -1)
The stack for each of you seperate cogs is too small. Notice how in the driver I put that the:
writeByte(EEPROMaddress, value) '' 19 Stack Longs
Requires 19 stack Longs. You only allocated 20 longs to the stack of the processor. Try increasing the stack to 40 for each processor.
I hope that helps.
Also, you may wish to use the http://obex.parallax.com/objects/497/ to generate audio.
So... no more crashing while buttons pressed. I changed the stacl space to 600 for now.
I did not know exactly how to implement the stack space specifically for that application. I assume it is in the named "stack" space.
I was also missing a repeat at end of PUB START so LED's didn't stay on ...except for a flash.
Now, when rebooting the prop I always get pin15 to light (zero read from memory) ...so did I not write to EEPROM?? {I PUSHED INPUT BUTTON...assuming write bit to memory:=1. Then turned off the Prop. Then rebooted.}.
Any suggestions to further this experiment???
CON _clkmode = xtal1 + pll16x ' Feedback and PLL multiplier _xinfreq = 5_000_000 ' External oscillator = 5 MHz BEEPpin =9 ' AUDIO CONFORMATION INJECTION PIN OBJ ROM:"I2C_ROMEngine" VAR LONG STACK [600] ' STACK byte EOMhistory ' history read variabel byte GOODbeep byte GOODbonk ' Audio conformation variables byte BEEP PUB START 'START COGS TURNING ROM.ROMEngineStart(29, 28, -1) DIRA[BEEPpin]~~ DIRA[27]~~ DIRA[15]~~ COGNEW (WRITEtest(0), @STACK[100]) COGNEW (BEEPMODULE(0),@STACK[400]) EOMhistory:=ROM.readByte($7000) '***I2C READ BYTE TEST**** if EOMhistory==1 outa[27]:=1 'Read history byte from EEPROM; light app LED elseif EOMhistory==0 outa[15]:=1 REPEAT PUB WRITEtest(writeVAR) '***I2C WRIE BYTE TEST**** repeat if INA[11] ==1 GOODbeep:=1 ROM.writeByte($7000, 0) 'Depending on STATE of pushbutton write a "0" or "1" to EEPROM elseif INA[11]==0 GOODbonk:=1 ROM.writeByte($7000, 1) WAITCNT(CLKFREQ+CNT) 'Wait a little bit. Then do it again PUB BEEPMODULE (BEEPVAR1) ' ***HIGH/LOW AUDIO GENERATION MODULE*** DIRA[BEEPpin]~~ ' Turn on direction rigister for beep pin Repeat ' Loop for a long time Repeat while GOODbeep==1 ' Do this loop if the GOODbeep variable has been set to a 1 REPEAT 3 ' Do the same thing 3 times WAITCNT(CLKFREQ/18+CNT) ' Give a short duration between beeps (1/18 second) REPEAT BEEP FROM 1 TO 100 ' Do this loop 99 times !OUTA[BEEPpin] ' Cycle pin waitcnt(clkfreq/1000+cnt) ' Wait 1/1000 of a second OUTA[BEEPpin]:=0 ' Set BEEPpin to off state GOODbeep:=0 'Reset the GOODbeep flag to zero when done. Return to top of loop and wiat for flag to set. repeat while GOODbonk==1 REPEAT 3 ' Do the same thing 3 times WAITCNT(CLKFREQ/18+CNT) ' Give a short duration between beeps (1/18 second) REPEAT BEEP FROM 1 TO 38 ' Do this loop 50 times !OUTA[BEEPpin] ' Cycle pin waitcnt(clkfreq/400+cnt) ' Wait 1/400 of a second OUTA[BEEPpin]:=0 ' Set BEEPpin to off state GOODbonk:=0As for you're program you doing things in a rather confusing way. I cannot comment to much on why the eeprom state reverts back to zero.
I would suggest using the object I posted a link to to make the tone output and I would suggest doing all that you are trying to in one cog.
Took it off of my Development Board #32111 and built it on my PE board with 2 pullups as Kye suggested.
Success!
So question is weather or not the Dev board is wired the same or not.
At any rate here is the simple code that works.
Pin 11 is state control button.
pin 17 is LED that is on when history returns a "0"
pin 21 is LED that is on when history returns a "1"
pin 19 is LED that is on when button (pin 11) is pushed.
When powered down while button not pushed (1) > reboot turns on pin 17.
When powered down while button is pushed (0) > reboot turns on pin 21.
Thanks so much Kye!
now to find out why it did not work on other board!
here is simplified code that works on the PE with 2 pullup resistors:
' TESTING WRITING TO PROM MEMORY CON _clkmode = xtal1 + pll16x ' Feedback and PLL multiplier _xinfreq = 5_000_000 ' External oscillator = 5 MHz OBJ ROM:"I2C_ROMEngine" VAR LONG STACK [600] ' STACK byte EOMhistory ' history read variabel PUB START ROM.ROMEngineStart(29, 28, -1) DIRA[11]:=0 DIRA[21]~~ DIRA[19]~~ DIRA[17]~~ EOMhistory:=ROM.readByte($7000) '***I2C READ BYTE TEST**** if EOMhistory==0 outa[17]:=1 'Read history byte from EEPROM; light app LED elseif EOMhistory==1 outa[21]:=1 repeat if INA[11] ==1 ROM.writeByte($7000,0) 'Depending on STATE of pushbutton write a "0" or "1" to EEPROM elseif INA[11]==0 ROM.writeByte($7000,1) outa[19]:=1 WAITCNT(CLKFREQ/3+CNT) 'Wait a little bit. Then read the buttons again. } OUTA[19]:=0
