GPS Receiver Module - Raw Mode
VanceShelley
Hello everyone.
I have scoured the forums and can't seem to find anyone that's using RAW mode on the GPS Receiver Module(item code #28146). I have pulled /RAW LOW and receive garbage data. Smart mode works just fine. I can send the !GPS commands and get the replies perfectly. However, I'm more interested in just receiving the NMEA sentances at 1Hz.
The baud setting (4800,n,8,1) is the same baud setting used in smart mode, so I'm sure the baud is ok, but in my experience with modems back in the day, the data looks more like it has a parity or baud rate error. The length of the data appears to be appropriate, but it appears to be random characters.
The only thing I can think of at this point is that the data must be coming in too fast for me to fire it off one byte at a time to the debug port, but I would expect to at least be seeing recognizable portions of the NMEA sentences if that was the case.
So I submit to you, my fellow Parallax People, I am in need of help.
Below you will find the code I am using.
Thanks!!
Thanks!!
' {$STAMP BS2} ' {$PBASIC 2.5} SI PIN 1 ' serial input RAW PIN 4 '/raw sData VAR Byte ' data buffer open CON $8000 T2400 CON 396 T4800 CON 188 T9600 CON 84 baud CON T4800 GetInfo CON $00 GetValid CON $01 GetSats CON $02 GetTime CON $03 ver_hw VAR Byte ver_fw VAR Byte tmHr VAR Byte tmMin VAR Byte tmSec VAR Byte sats VAR Byte smartMode VAR Bit smartMode = 1 IF (smartMode = 0) THEN SetRaw HIGH RAW GOTO Init SetRaw: LOW RAW Init: INPUT SI DEBUG "Beginning...", CR Main: IF (smartMode = 0) THEN RawInput SEROUT SI, baud, ["!GPS", GetTime] SERIN SI, baud, 3000, Init, [tmHr, tmMin, tmSec] DEBUG CLS, "Time of day (UTC): ", DEC2 tmHr, ":", DEC2 tmMin, ":", DEC2 tmSec, CR 'SERIN SI, 188, 3000, Init, [ver_hw, ver_fw] 'SERIN SI, baud, 3000, Init, [sats] 'DEBUG HEX ver_hw.HIGHNIB, ".", HEX ver_hw.LOWNIB, CR 'DEBUG HEX ver_fw.HIGHNIB, ".", HEX ver_fw.LOWNIB, CR 'DEBUG sats, CR PAUSE 500 'This delay is set to 500ms, because of the delay in the Smart Mode 'is about 500ms also, so the update freq. is 1Hz. If you change it to 'Pause 1000, you'll see the time jump in increments of 2 seconds ' sometimes. GOTO Main RawInput: SERIN SI, baud, 3000, Init, [sData] DEBUG sData GOTO Main
http://forums.parallax.com/showthread.php?t=116761
