How to get out of "threaded" "display mode" ? — Parallax Forums
RaymanRayman Posts: 16,320
edited 2010-08-13 05:17 in General Discussion
Seems I made a mistake and tried out "threaded" mode and now every post I look at starts in "threaded" mode.
There's a setting in "user CP" that looks like it's supposed to set the default, but it doesn't have any effect...
What am I doing wrong here?
  • SeariderSearider Posts: 290
    edited 2010-08-12 09:37
    Rayman, When I checked out the threaded mode, I had the same problem trying to turn it off. After fiddling with it for awhile I was able to get it back to linear mode.
    For me I thought it was that I would use "Back" key after I made the change and that put be back to page that I had viewed as Threaded. I suspected that this caused the mode to flip back to threaded. I was able to fix the issue by going the userCP page, making the change and then exiting and re-entering the forum.
    It could be something else as I did not repeat to prove my theory. regardless, I would suggest continuing to try.
  • RaymanRayman Posts: 16,320
    edited 2010-08-12 09:49
    I'm still stuck. User CP still says linear even though every post I look shows up threaded...
  • Roger LeeRoger Lee Posts: 339
    edited 2010-08-12 14:52
    Is this it Ray?
    Just above top post, pull down menu "Display Modes"
    Edit: well that didn't work... inline image issue.
    Better .. changed from bmp to jpg image.
    Nothing to see here - did not apply to the situation.
    622 x 216 - 41K
    edited 2010-08-12 19:43
    Phil suggested clearing cookies for a different issue. This is always a good idea with problems of this nature.
  • Jim EwaldJim Ewald Posts: 733
    edited 2010-08-12 20:20
    Yes, we have seen several cases now where cookies that were in place before we made the last database change didn't get deleted like they should have.
    Searider wrote: »
    Ok, I found the forum's cookie and deleted it and now it's all better...
    In IE8 click on Tools->Internet Options and then on the General tab click on Browsing history->Settings. Then, click "View files" and look for cookie:username@forums.parallax.com/ where username is your login name. Delete that file and you're all better...
