Pulling a pin high — Parallax Forums
Pulling a pin high
SiriSiri Posts: 220
edited 2010-08-13 07:59 in Propeller 1
Is it ok to pull a pin high(connecting to + ve 3.2V directly) or do I have to use a resistor.
If so what value would I use.
Will this also return 1(high) -when INA is used to read the state of the pin.
Siri
    edited 2010-08-11 21:02
    If the I/O pin is always an input and can't ever be an output, you could tie the I/O pin to either Vdd (+3.3V) or Vss (ground). Unfortunately, if the I/O pin ever gets accidentally (though a programming mistake) set to output mode and the I/O pin state is opposite from the way you've connected it, you may instantly damage the I/O pin circuitry in the chip.
    It's always much safer to use a series resistor that will limit the fault current to something the chip can handle. A minimum of 100 Ohms will work, but a 1K to 10K resistor is much better. Most circuits I've seen use something like 10K.
    INA will return 1 bits for any input pins with a voltage greater than 1/2 of Vdd (1.65V usually). The Propeller datasheet gives the exact value.
  • SiriSiri Posts: 220
    edited 2010-08-11 21:20
    Thanks Mike for the prompt reply.
    Siri
  • BeanBean Posts: 8,129
    edited 2010-08-12 03:29
    In Mike's example, a low resistor value (100 ohms) would be called a "strong" pull-up.
    A larger value (10K) is called a "weak" pull-up.
    Bean
  • ErNaErNa Posts: 1,850
    edited 2010-08-12 04:32
    In the case, that the signal is constant, a soft pull-up is sufficent. The resistor forms a voltage source with a certain output impedance, so external influences can disturb the voltage output. Normally, the input is variable and if driven by an switch to ground, the time constant created by input capacity and pull-up resistor determines the maximum signal speed. So there are two reasons to have a strong pull-up: decrease time constant of R/C filter and improve IME.
    Thanks for all that info what resistor to use and when.
    Siri
