Thread porting test - nothing to see here - move right along!
Introduction
_
Like the blue enhanced photodiode from Applied Sensors, light emitting diodes (LEDs) also conduct current at different rates with different levels of light exposure._ Since the currents are very small for ambient light levels, it turns out that the stray capacitance in the I/O pin, the metal clip under the breadboard row, and the LED's silicon junction store enough charge to make the RCTIME measurement work._ Try the attached circuit and code under controlled conditions._
_
Circuit
_
_
Source Code
_
' TestIrLedFlameDetect.bs2
' See TestIrLedFlameDetect.PDF for Schematic.
_' This is a novel application that uses the Boe-Bot
' robot's IR LEDs to detect flame in an area devoid
' of other sources of IR such as sunlight and halogen
' lamps.
_
' {$STAMP BS2}
' {$PBASIC 2.5}
_
time VAR Word
_
DO
_ HIGH 8
_ RCTIME 8, 1, time
_ DEBUG HOME, CLREOL, ? time
_ PAUSE 100
LOOP
_
Procedure
_
Make sure to keep the blinds drawn and eliminate other sources of IR such as incandescent lights._ Try the schematic and source code that begin with the word Test first, and make sure the Debug Terminal reports significantly lower measurements when a flame is shown to the dome on the LED._ Under these conditions, I've been able to discern an open (candle) flame up to a meter away._ Mind your cathodes and anodes too._ The IR LED is connected backwards from the way we usually connect it to emit IR for object detection._
_
Your Turn
_
You can also try colored LEDs (red, green, yellow, blue) for detecting ambient light, or even use some colored LEDs_and IR LEDs to better discern flame from ambient light sources.
___________________________________
Andy Lindsay
Education Department
Post Edited (Andy Lindsay (Parallax)) : 1/23/2008 4:22:42 AM GMT
Image Attachment :
Flame Detect Test Circuit.jpg _ 16KB (image/pjpeg)This image has been viewed 2757 time(s).
File Attachment :
TestIrLedFlameDetect.pdf _ 30KB (application/pdf)This file has been downloaded 370 time(s).
File Attachment :
TestIrLedFlameDetect.bs2 _ 1KB (application/octet-stream)This file has been downloaded 357 time(s).
_
_
Circuit
_
_
Source Code
_
' lamps.
_
' {$STAMP BS2}
' {$PBASIC 2.5}
_
time VAR Word
_
DO
_ HIGH 8
_ RCTIME 8, 1, time
_ PAUSE 100
LOOP
_
Procedure
_
_
Your Turn
_
Andy Lindsay
Image Attachment :
File Attachment :
File Attachment :
IMPORTANT: Be sure to do a 'Preview Changes' first to make sure it's what you want!
Introduction
_
_
Circuit
_
_
Source Code
_
' lamps.
_
' {$STAMP BS2}
' {$PBASIC 2.5}
_
time VAR Word
_
DO
_ HIGH 8
_ RCTIME 8, 1, time
_ PAUSE 100
LOOP
_
Procedure
_
_
Your Turn
_
Andy Lindsay
Image Attachment :
Flame Detect Test Circuit.jpg _ 16KB (image/pjpeg)This image has been viewed 2759 time(s).
File Attachment :
File Attachment :
_
_
Circuit
_
_
Source Code
_
' lamps.
_
' {$STAMP BS2}
' {$PBASIC 2.5}
_
time VAR Word
_
DO
_ HIGH 8
_ RCTIME 8, 1, time
_ PAUSE 100
LOOP
_
Procedure
_
_
Your Turn
_
Andy Lindsay
Image Attachment :
Flame Detect Test Circuit.jpg _ 16KB (image/pjpeg)This image has been viewed 2760 time(s).
File Attachment :
File Attachment :
_
_
Circuit
_
_
Source Code
_
' lamps.
_
' {$STAMP BS2}
' {$PBASIC 2.5}
_
time VAR Word
_
DO
_ HIGH 8
_ RCTIME 8, 1, time
_ PAUSE 100
LOOP
_
Procedure
_
_
Your Turn
_
Andy Lindsay
Image Attachment :
Flame Detect Test Circuit.jpg _ 16KB (image/pjpeg)This image has been viewed 2774 time(s).
File Attachment :
TestIrLedFlameDetect.pdf _ 30KB (application/pdf)This file has been downloaded 371 time(s).
File Attachment :
TestIrLedFlameDetect.bs2 _ 1KB (application/octet-stream)This file has been downloaded 358 time(s).
