How to set up a clk signal and receive bits from a 16bit A/D converter
Hey all,
Im reading through one of deSilva's tutorials and am slowly learning assembly language..
my goal is to communicate with a 16bit A/D converter using mostly assembly (but if spin works well for this, that would be nice to know too).
i learn much faster when i am able to manipulate code that i can understand! so while im learning assembly language i would really like to be able to look at some basic code concepts so that the terms and symbols are in my mind.
if anyone has a code example they could share and wouldn't mind commenting on it just a little, that would be really helpful!!!
thank you!
[edit] i should specify that this is a serial A/D converter
the datasheet is here: http://focus.ti.com/lit/ds/symlink/ads7813.pdf
thank you!
http://obex.parallax.com/objects/625/
http://obex.parallax.com/objects/85/
oh wow! the methods provided in that object are really easy to understand. Im still trying to evaluate the assembly code, but the spin makes perfect sense!!
thanks!!!!
