5V Power supply
Hey I am working on a project involving the basic stamp 2 chip, and my problem is how to get power running through it. I was thinking of getting a phone charger with a 5V output, cutting the wire and attaching it to the breadboard. Would that work? or are there any other simple/cheap solutions?
Oh, excuse me, it's $1.47.· Get the right "Adapta-plug" with it -- 2.1 mm inner, 5.5 mm outer.
And hook it up "Center Positive".
Post Edited (allanlane5) : 8/5/2010 6:17:08 PM GMT
A better approach: you can use one of these http://www.kronosrobotics.com/xcart/product.php?productid=16304&cat=287&page=1 for $15 or so, along with the wall-wart -- that will give you an amp of current at 5 volts for your BS2 AND your other circuits.
Oh, and if you use the KronosRobotics unit, you'll need a 7.5 volt wall-wart -- the 7805 regulator used on it won't put out 5 volts with a 6 volt supply.
http://www.adafruit.com/index.php?main_page=product_info&cPath=38&products_id=184&zenid=a84f4dd5e6753457ce1613ef616db7e4
- Stephen
- Stephen
Eventually you'll want to spring for one of those nifty breadboard regulators as they are really handy. When you do that you may find that a 5V adapter isn't enough. This is because the voltage regulator is not 100% efficient and you need higher than 5V to supply 5V.
You might be ok if you have a charger for one of the really old phones.... that used NiCd or NiMh.... I don't know that I'd try to use a recent charger for Lithium cells.
Do you have any old printers? Scanners? Maybe a cordless phone wall-wart??
I'd use batteries before I used the newer cell charger.
I am new to electronics and programming, I would be completely lost right now without this forum. Help is appreciated
My rule with ANY PSU . Is to use a O scope . or at least a meter on the AC scale to see the AC ripple and how bad it is .
And in DC mode I put a load on it just to see if its regulated well and what not .
When ever I get a walWart I wil do theas tests and label my bricks with there Real Specs .
If its heavy and what not its Iron core and may or may not be Regulated . if is light like a cell charger then is most likely a SMPS and will have good regulation for the most part ..
Most of those cell chargers are not the active part of the charge loop . the IC IN the Phone is doing the chargecontroll .
EDIT looking at the spare charger for my palm Centro , its a flat 5 V
the only down side is its .5A so for a ton of servos it may glitch in to protection mode . .
Peter KG6LSE
