Is SPIN "inlining" functions?
Hi all,
Let's imagine I have this code:
Will that be as fast as:
I mean, is the spin compiler doing some inlining (not sure of the term here)? Or do I need to do it manually? Or do we have a way to ask him to do it?
JM
PUB Main repeat outxy(1,2,48) PUB outxy(x, y, c) screen[noparse][[/noparse]y * cols + x] := (color << 1 + c & 1) << 10 + $200 + c & $FE
PUB Main repeat screen[noparse][[/noparse]2 * cols + 1] := (color << 1 + 48 & 1) << 10 + $200 + c & $FE
JM
http://en.wikipedia.org/wiki/Compiler_optimization
x := 5
y :=5
z := x+y
is twice faster than
x := 5
y := 5
z := f(x,y)
where f return x+y.
So I will look at my code at the end, and if I still have some memory available, I will probably try to do some manual inlining...
http://en.wikipedia.org/wiki/Inline_expansion
JM
Linux? There is worst, but it's more expensive.
Something else to consider ... in-lining is a trade off between execution speed and code size and the Propeller is mostly constrained by available memory. Unless a piece of code involving method calls is executed a lot, there's probably no effective advantage in in-lining the code. You have to do the analysis of execution time patterns after the program is all done and working in order to see where in-lining will help.
Post Edited (Mike Green) : 8/5/2010 6:35:33 PM GMT
Thanks for your feedback.
I was thinking about inlining when I saw that in another post:
getBit is very small. So I was wondering if it's beter to use this method, or to inline it. Even for the memory. This method should take only few longs, but calling it should take the same.
Anyway, so far I still have half of the memory available, even with the screen-driver. So I will not start to do such optimizations, but I was just wondering. I will have to review all my code when it will be over to see if such optimization can be a +, or a -...
JM
Update: forgot the CODE tags...
Message Edité (jmspaggi) : 8/5/2010 6:56:08 PM GMT
There's no reason not to inline getbit, just watch your precedence if target or pos is an expression. getbit too unless it's used a huge number of times.
Composite NTSC sprite driver: Forum
NTSC & PAL driver templates: ObEx Forum
OnePinTVText driver: ObEx Forum
