Giving out pulses using propeller chip — Parallax Forums
prabhatprabhat Posts: 4
edited 2010-08-05 17:23 in Propeller 1
I am trying to program a robot with servos on its joints which are controlled by a propeller. Its a HS 422 servo. It has a neutral at 1.5ms pulse. I am trying to give this pulse using the clkfreq and waitcnt but never getting it right. The servo who run to an extreme and hit a mechanical limit. I am not really sure if the pulses i am giving are of the right duration. 1.5ms every 20ms. the following is the code I used. Please help
CON
_clkmode = xtal1 + pll16x ' Feedback and PLL multiplier
_xinfreq = 5_000_000
Led = 1
PUB LedOnOff
dira[noparse][[/noparse]Led] := 1
repeat
outa[noparse][[/noparse]Led] := 1
waitcnt(clkfreq/667 + cnt)
outa[noparse][[/noparse]Led] := 0
waitcnt(clkfreq/50 + cnt)
Is there a problem with the code? I tried the servo with Basic stamp and that works fine.
Thank you in advance
Prabhat
  • JonnyMacJonnyMac Posts: 9,843
    edited 2010-08-04 20:02
    I wrote the attached program a couple months ago. It actually launches another Spin cog that serves as an 8-channel servo driver. As the whole thing is coded in Spin you might find it helpful.
    Jon McPhalen
    Hollywood, CA
    Post Edited (JonnyMac) : 8/4/2010 8:14:29 PM GMT
  • JavalinJavalin Posts: 892
    edited 2010-08-04 20:04
    have you looked at the servo objects in the OBEX? http://obex.parallax.com
    It does look like your code is wrong.· Maybe :
    us := clkfreq / 1_000_000   ' micro-seconds
    ms := clkfreq / 1_000       ' milliseconds
    twenty_ms := ms * 20        ' so we don't have to count each time
    one_pt_five_ms := us * 1500
    repeat
        waitcnt(one_pt_five_ms + cnt)
        waitcnt(twenty_ms + cnt)
    Might be a simple way to do it.· Note the indentation!
    edit - or this is a better way, as it provides a syncronised 1.5ms pulse - i.e. it begins every 20ms, rather than every 21.5ms as in previous loop.· (look at page 220 in the propeller manual)
    VAR
        long    syncDelay
        long    ms, us
    PUB Start
        one_pt_five_ms := us * 1500   '
        dira[noparse][[/noparse]Led]~~                   ' set to output
        syncDelay := cnt              ' setup syncronised delays
        repeat
            waitcnt(one_pt_five_ms + cnt)     ' wait for 1.5ms
            waitcnt(syncDelay += twenty_ms)   ' wait for the remainer of the 20ms
    James
    Post Edited (Javalin) : 8/4/2010 8:25:03 PM GMT
  • prabhatprabhat Posts: 4
    edited 2010-08-04 20:34
    I tried both the codes.. But surprisingly the same thing keeps happening. its driving me nuts because I am sure the mistake is something very fundamental. My servo would also wind up at one extreme and in fact pushing to go past it.
    edited 2010-08-04 20:39
    what crystal and hardware board are you using?
    james
    edited 2010-08-04 20:42
    I am using the prop stick usb platform. It has a 5 Mhz built in crystal
  • W9GFOW9GFO Posts: 4,010
    edited 2010-08-05 01:30
    Are you sure that you have the servo hooked up correctly?
    waitcnt((clkfreq/1_000_000) * 1500 + cnt) is easier to understand (in my opinion) and will work at any _clkmode or _xinfreq without modification.
    Rich H
    The Simple Servo Tester, a kit from Gadget Gangster.
    edited 2010-08-05 08:09
    but requires the delay to be calculated each and every time you run the line.
    so will mine.
    I'll run up the code on my dev board tonight & put the o'scope to work on it.
    Cheers,
    James
    Code from the second example posted works fine - full code·as run on my·prop-demo-board·is:
    CON
        LED                     = 5
    VAR
        long    syncDelay
        long    ms, us
        long    twenty_ms, one_pt_five_ms
    PUB Start
        us := clkfreq / 1_000_000     ' micro-seconds (so we don't calc each time)
        twenty_ms := ms * 20          ' so we don't have to calculate each time
        repeat
    Attachments to this post show the 1.5ms pulse (1ms per division) and the 20ms gap between the pulses (5ms per div).
    Cheers,
    James
    800 x 600 - 86K
    800 x 600 - 86K
