Generating text/video through the PROP using Prop Basic
Hello all! I am using the Prop Basic Editor to program my PROP. I have a question that I know someone out there can answer. How do you generate text to overlay on top of a video source but using the Basic Sntax? I have the hardware all hooked up per the PROP manual for the video in / out using the RCA jack, and three pins with the proper resistor ratings. Any help would be much appreciated. ( not too many laughs from the forum due to me using the PROP Basic Editor : )· )
No laughs from me. The Prop is so versatile and anything that is easy is the best way to start. You can progress to other things as your needs change. It is much better to use something you are familiar with to see what it can do.
Unfortunately, I cannot help you with your question, but I am certain you will have your answer shortly as this is an extremely active forum with huge number of helpful people.
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
· Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
You need more than that to do video overlay.
What you have will generate a video signal, but to overlay video you need to sense the sync pulses from the incoming video signal.
I think the Prop Backpack will do it. http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/backpack/List/0/SortField/4/ProductID/602/Default.aspx
Bean
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
NEW PropBasic Blog: http://propbasic.blogspot.com
NEW Rising Tite Computer Blog: http://risingtidecomputer.blogspot.com
There are two rules in life:
· 1) Never divulge all information
If you choose not to decide, you still have made a choice. [noparse][[/noparse]RUSH - Freewill]
