Parallax Demo Board — Parallax Forums
Parallax Demo Board
HumanoidoHumanoido Posts: 5,770
edited 2010-08-04 07:27 in Propeller 1
Got any good ideas for mounting a Parallax Demo Board on top of a Parallax Proto Board? The Proto has four holes. The Demo does not. Thanks in advance.
Humanoido
    edited 2010-08-03 17:39
    Find a blank copper circuit board of appropriate dimensions, drill 4 holes in corners, then use padded double adhesive tape to attach the Parallax Demo board.
    Ain't gadetry a wonderful thing?
    aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
    edited 2010-08-03 18:06
    Unless you're using the Proto Board's servo header pads for servo motors, you can remove that tall 1000uF cap to make a thinner "sandwich".
    I see that the copper clad mount board could also be a piece of wood, masonite or Plexiglas. If the electrolytic capacitor is removed, it will gain about 1/16th to 1/8th-inch of space. Then the power jack is in the way. Next is the slide switch.. I'm sure some board space is needed for cooling..
    Actually I was going to remove the Propeller chip from the Demo Board and insert it into the UltraSpark 40 SkyScraper, until seeing it was not a removable DIP! What a shocking and horrific sight!!! [noparse]:)[/noparse] Wish I could trade up all the SMTs for DIPs.
    humanoido
