detecting running persons
Hi all
I 'm starting on a new project where I 'm placed with the following problem.
I need to detekt a running person from normal walking persons. I have mechanicaly a coridore where everyone have to walk throug. I can place 5 IR beam sensors in that coridor on a strait horizontal line 50 cm from each other.
My questions now.
Is a propeller fast enouf to detekt the pulses from the sensors when somebody is walking true the coridore and can I make the differance between walking and running?
I found some beam sensors from omron where I get a responce time below 2 ms. They are open collector output and powerd on 12 V DC. How do I safly connect them to the propeller with minimal electronic material between and fasted reaktion.?
Any comment is welcome on this topic.
Stef
My questions now.
Stef
Leon Heller
Amateur radio callsign: G1HSM
Graham
www.irisys.co.uk
and designed the hardware and ported the software for their first commercial people counter. That could be reprogrammed to detect the speed of individual persons, even in a crowd. Development costs would be quite high, though.
Leon Heller
Post Edited (Leon) : 8/3/2010 11:21:50 AM GMT
Graham
Leon
I kwnow the irisys product. I used them already I some other projects. They are good but to expensive for this project.
What do you mean by "accelerometers"? Can you give me an example?
Graham
They are beam type sensors. I know that it can not detect when croud is passing (more than One person at the thime) That is not an issue. It is mechanicly constructed that it is persone by personen that neet to pass. So that is not an issue.
Is thier somebody that knows how to connect the open collector to the propeller. Thake in attention the higer voltage of the sensor. I think that will bring the open collector also to the wrong level. I can chouse between NPN or PNP.
Stef
Leon Heller
In that case you should have no problems, compared to the speed of the propeller the speed of mere humans is nothing, you could build something to detect the speed of bullets with the prop.
Which open collector are you referring to? If the output of the sensor is open collect then you just need to attach a pull up to 3v and connect straight to the prop. Remember an open collector just pulls the collector down to ground when switched and nothing else.
Graham
I will try it out.
stef
Why did I think a new, more challenging, job was a good idea ??
