PINK Program help
Please HELP>>>>>>>>>>>>>>>
I have spent many hours trying to write a Spin email program for the PINK module.
I am trying to write a SPIN program of just the bare bones needed to send an email message. I first tried the PINK program in the object exchange. I was unable to make it work. The object is written for a Spin Stamp Board, and to be honest, is about three levels above my skill set. I then took the Stamp program that came with the Pink module from Parallax. I took out the essential elements and converted them to spin. The program ran but never generated an email message. I suspect I missed some element that is needed, or my coding is bad.
When I initially received the Pink module, I did all of the configurations and also installed the firmware update provided by Tech support. The Stamp program did work and I was able to receive emails generated by the PINK module.
Attached to this post is the Stamp program provided with the module.
Here is the Spin program I am trying to use:
(I have omitted the actual addresses)
CON
_clkmode = xtal1+pll8x
_xinfreq = 10_000_000
' propeller xmit to pink receive pin 10
' propeller receive to pink xmit pin 11
OBJ
ser : "FullDuplexSerial"
pub main
ser.start(11, 10, 0, 9600)
ser.str(string("NB0WET:xxxxx@comcast.net")) 'send message to
ser.str(string("0"))
ser.str(string("NB0WEF:xxxxx@comcast.net")) 'message is from
ser.str(string("NB0WES:this is the subject line")) 'subject line
ser.str(string("NB0WEC:this is the message content")) 'message content
ser.str(string("NB0WEV:smtp.comcast.net")) 'smtp info
Post Edited (lfreeze) : 8/2/2010 11:07:04 PM GMT
CON
OBJ
pub main
As for posting samples of your code, place your code between these two tags except remove ALL of the empty spaces
[noparse][[/noparse] code ]
[noparse][[/noparse] / code ]
That way your code will preserve the proper indentation2400. When I ran the program again, it did send an email. Several subsequent runs did not work. I rebooted the pink module and relaoded the pink firmware update. I ran the program again and it sent another email. I tried several more runs and it did not send any messages. I'm totally confused by this behavior and
think it may be a timing issue or a pink problem.
I believe the program issue is resolved, a big thank you for your help. I will try some variations on the config page and if it continues to fail,
I'll appeal to Parallax for an RMA number..
Larry
