Visual Spin: Alpha 4 Release (update) — Parallax Forums
RaymanRayman Posts: 16,457
edited 2011-04-20 13:26 in Propeller 1
Almost finished!
It currently supports standard VGA monitor connections (such as with Demo or Proto boards).
Added check boxes and option buttons and form bitmaps.
You can change color schemes with the Application->Colors buttons.
If your PC monitor isn't huge,use the View->Forms 50% to shrink the form view so you can see everything.
You can now edit custom code by double clicking on buttons (or clicking the Application->Handler Code ribbon-bar button).
It can program a Prop chip itself. Use the Build->Build App dialog to see the complete code and program the Prop's RAM.
Get this latest version here:
http://www.rayslogic.com/propeller/Programming/VisualSpin/VisualSpin.htm
Saved documents from previous alpha versions won't work.
Here's a little test project file for this version:
Note: These attachments are currently broken thanks to our new forum transition. Maybe they'll fix them, but I'll try to put them on my website in case they can't....
My Prop Apps: http://www.rayslogic.com/propeller/Programming/Programming.htm
My Prop Info: http://www.rayslogic.com/propeller/propeller.htm
My Prop Products: http://www.rayslogic.com/Propeller/Products/Products.htm
Post Edited (Rayman) : 8/5/2010 3:53:35 PM GMT
1406 x 942 - 110K
