24LC256 EEPROM, Can it run faster???
so i was just reading the datasheet of the typical 24LC256 and it says:
Datasheet: http://wulfden.org/downloads/datasheets/24LC256.pdf
would it even be possible for the propeller to download from the eeprom at 1 MHz???
24LC256 DATASHEET said...
2.2 Serial Data (SDA)
This is a bidirectional pin used to transfer addresses
and data into and out of the device. It is an open drain
terminal. Therefore, the SDA bus requires a pull-up
resistor to VCC (typical 10 kΩ for 100 kHz, 2 kΩ for
400 kHz and 1 MHz).
it's not gone help as I think the timming is set in the bootloader in ROM.
If you want to read from the eprom later in a faster speed it could probably be done.
