Sound Question — Parallax Forums
Sound Question
MausmanMausman Posts: 16
edited 2010-08-01 17:50 in Propeller 1
Hi all, where in spin can i change the left and right audio outputs?
Tia, Mausman
    edited 2010-07-31 12:38
    audio outputs for which propeller-board using which program to create the sound?
  • MausmanMausman Posts: 16
    edited 2010-07-31 14:09
    i made my own board with 2 propellor chips , one of them has rayman's 4" lcd.
    as for now easyer to put the sterio out on different pins, like p15 and p16.
    redesigning the whole board is a lot of work, so if possible i can send the files to prototype the board.
    edited 2010-07-31 17:13
    Of course it is easier to change an IO-pin-number than re-designing the board.
    Still depends on the program that you are using
    edited 2010-08-01 09:34
    for starters just the vocal sound of the lib demo
  • AribaAriba Posts: 2,697
    edited 2010-08-01 10:14
    Most sound objects allows to pass the audio out pin numbers as parameters in the start methode.
    So also the vocal track object. In the vocal examples you see the numbers 10 and 11 for the audio pins of the demo board.
    Andy
    ok thanks, i will give it a try it tomorow
