GE865 Evaluation Board
Dear all,
does anyone know about GSM "GE865 Evaluation Board"??
I wanna know which software should i use with this boad??? I wanna use this GSM with basic stamp#2 to control lighting in my home by using sms order??? plz tell me the highlight to use the GSM model???
best wishes,
thx
best wishes,
thx
Leon Heller
Amateur radio callsign: G1HSM
Leon Heller
Leon Heller
Leon Heller
;============================================================================= ; Filename: GSM.asm ;============================================================================= ; ; Test software for Telit GE863-GPS module GSM function ; ; MCU: 16F88 ; ; Author: Leon Heller ; Company: ; ; Revision: 1.00 ; Date: August 7, 2007 ; Initial working version ; ; Revision: ; Date: ; ; ; Assembled using MPASMWIN V5.02 ; ; Home number: ATDT01424714790 ; Mobile number: ATDT07890408969 ;============================================================================= ;============================================================================= ; Include Files: p16f88.inc ;============================================================================= list p=16f88 ;list directive to define processor #include <p16f88.inc> ;processor specific definitions errorlevel -302 ;suppress "not in bank 0" message ;---------------------------------------------------------------------------- ;Constants SPBRG_VAL EQU .11 ;set baud rate to 38,400 for 7.3728 Mhz clock CR EQU 0x0D LF EQU 0x0A DLY_COUNT EQU 0xFF Timeout_100ms EQU .10 Timeout_5s EQU .255 ;---------------------------------------------------------------------------- ;#defines #define INIT_COUNT D'0' ;gives ~10 ms between interrupts #define LED 3 ;---------------------------------------------------------------------------- ;Bit Definitions GotNewData EQU 0 ;bit indicates new data received ;---------------------------------------------------------------------------- ;Variables CBLOCK 0x020 Flags counter delay_counter1 delay_counter2 MSGPTR Terminator Temp Timeout TimeoutCounter Buffer: 50 ENDC ;---------------------------------------------------------------------------- ;This code executes when a reset occurs. ;reset vector org 0 clrf PCLATH goto main ;---------------------------------------------------------------------------- ;interrupt vector org 4 banksel INTCON bcf INTCON,TMR0IF ;clear Timer0 interrupt flag movlw INIT_COUNT ;re-initialise count movwf TMR0 incf TimeoutCounter,f;inc. timeout counter movfw Timeout ;timed out? subwf TimeoutCounter,w skpz ;no, return retfie bsf Flags,0 ;yes, set timeout flag retfie ;---------------------------------------------------------------------------- main: ;------------------------------------------------------------------ ;initialisation banksel OPTION_REG movlw b'00000111' ;prescaler 1/256 movwf OPTION_REG ;giving 7.3728 Mz/256 = 28800 Hz (period = 35 us) banksel TMR0 movlw INIT_COUNT ;initialise timer count value movwf TMR0 bsf INTCON,TMR0IE ;enable Timer0 interrupt banksel PORTA bcf PORTA,LED banksel TRISA bcf TRISA,LED ;RA3 (Error LED) output call ClearBuffer banksel Flags clrf W movwf Flags call SetupSerial ;set up serial port and buffers bsf INTCON,GIE ;enable global interrupt ;------------------------------------------------------------------------- ;send commands to GSM ;initial check (100ms timeout) call ClearBuffer call OUTMSG1 ;send AT call Timeout100ms main1: call ReceiveSerial ;get char in W movwf INDF ;save in buffer movwf Temp incf FSR,F ;bump pointer btfss Flags,0 ;timeout flag set? goto main1 ;no, try to get more chars call dly ;yes, continue nop ;enable extended error result codes (100ms timeout) call ClearBuffer call OUTMSG2 ;send AT+CMEE=1 call Timeout100ms main2: call ReceiveSerial ;get char in W movwf INDF ;save in buffer movwf Temp incf FSR,F ;bump pointer btfss Flags,0 ;timeout flag set? goto main2 ;no, try to get more chars call dly ;yes, continue nop ;Check SIM presence call ClearBuffer call OUTMSG3 ;send AT+CPIN? call Timeout100ms main3: call ReceiveSerial ;get char in W movwf INDF ;save in buffer movwf Temp incf FSR,F ;bump pointer btfss Flags,0 ;timeout flag set? goto main3 ;no, try to get more chars call dly ;yes, continue nop ;query network status (5s timeout) ;returns +CREG 0,1 if OK call ClearBuffer call OUTMSG4 ;send AT+CREG? clrf TimeoutCounter call Timeout5s main4: call ReceiveSerial ;get char in W movwf INDF ;save in buffer movwf Temp incf FSR,F ;bump pointer btfss Flags,0 ;timeout flag set? goto main4 ;no, try to get more chars call dly ;yes, continue nop ;Test call ClearBuffer call SCRATCH ;send AT+CMGF=1 call Timeout5s main5: call ReceiveSerial ;get char in W movwf INDF ;save in buffer movwf Temp incf FSR,F ;bump pointer btfss Flags,0 ;timeout flag set? goto main5 ;no, try to get more chars call dly ;yes, continue nop ;Check SMS Service Centre Number ;Returns +CSCA:<number>,<type> call ClearBuffer call OUTMSG6 ;send AT+CMGF=1 call Timeout100ms main6: call ReceiveSerial ;get char in W movwf INDF ;save in buffer movwf Temp incf FSR,F ;bump pointer btfss Flags,0 ;timeout flag set? goto main6 ;no, try to get more chars call dly ;yes, continue nop goto _Error ;---------------------------------------------------------------------------- ;Set up serial port. SetupSerial: banksel TRISB movlw 0x04 ;set tris bits for TX and RX iorwf TRISB,F movlw SPBRG_VAL ;set baud rate movwf SPBRG movlw 0x24 ;enable transmission and high baud rate movwf TXSTA banksel RCSTA movlw 0x90 ;enable serial port and reception movwf RCSTA return ;---------------------------------------------------------------------------- ;Check if data received and if so, return it in the working register. ReceiveSerial: banksel Flags btfsc Flags,0 ;timeout flag set? return ;yes, return banksel PIR1 btfss PIR1,RCIF ;check if data goto ReceiveSerial btfsc RCSTA,OERR ;if overrun error occurred goto ErrSerialOverr ; then go handle error btfsc RCSTA,FERR ;if framing error occurred goto ErrSerialFrame ; then go handle error movf RCREG,W ;get received data return ReceiveSerialWait: banksel PIR1 btfss PIR1,RCIF ;check if data goto ReceiveSerialWait movf RCREG,W ;get received data return ;error because OERR overrun error bit is set ;can do special error handling here - this code simply clears and continues ErrSerialOverr: bcf RCSTA,CREN ;reset the receiver logic bsf RCSTA,CREN ;enable reception again return ;error because FERR framing error bit is set ;can do special error handling here - this code simply clears and continues ErrSerialFrame: movf RCREG,W ;discard received data that has error return ;------------------------------------------------------------- Timeout100ms: clrf TimeoutCounter movlw Timeout_100ms movwf Timeout bcf Flags,0 ;clear timeout flag movlw Buffer ;initialise buffer pointer movwf FSR return ;-------------------------------------------------------------- Timeout5s: clrf TimeoutCounter movlw Timeout_5s movwf Timeout bcf Flags,0 ;clear timeout flag movlw Buffer ;initialise buffer pointer movwf FSR return ;---------------------------------------------------------------------------- ;Transmit data in WREG when the transmit register is empty. TransmitSerial: banksel PIR1 btfss PIR1,TXIF ;check if transmitter busy goto $-1 ;wait until transmitter is not busy movwf TXREG ;and transmit the data return ;--------------------------------------------------------------------------- ;ClearBuffer ClearBuffer: movlw Buffer movwf FSR movlw .50 movwf counter Clear1: movlw 0x00 movwf INDF incf FSR,f decf counter,f bz Clear2 goto Clear1 Clear2: return ;----------------------------------------------------------- ;Initial check - send AT ;----------------------------------------------------------- OUTMSG1 clrf MSGPTR ; put 'W' into message pointer MSG1_LOOP MOVF MSGPTR, W ; put the offset in 'W' CALL MSG1 ; returns ASCII character in 'W' ADDLW 0 ; sets the zero flag if W = 0 BTFSC STATUS, Z ; skip if zero bit not set RETURN ; finished if W = 0 CALL TransmitSerial ; output the character INCF MSGPTR, f ; point at next GOTO MSG1_LOOP ; more characters MSG1 ADDWF PCL,f ; offset added to PCL dt "AT",CR,0 ;----------------------------------------------------------------- ;Enable extended error result codes ;----------------------------------------------------------------- OUTMSG2 clrf MSGPTR ; put 'W' into message pointer MSG2_LOOP MOVF MSGPTR, W ; put the offset in 'W' CALL MSG2 ; returns ASCII character in 'W' ADDLW 0 ; sets the zero flag if W = 0 BTFSC STATUS, Z ; skip if zero bit not set RETURN ; finished if W = 0 CALL TransmitSerial ; output the character INCF MSGPTR, f ; point at next GOTO MSG2_LOOP ; more characters MSG2 ADDWF PCL,f ; offset added to PCL dt "AT+CMEE=1",CR,0 ;---------------------------------------------------------------- ;Check SIM presence ;---------------------------------------------------------------- OUTMSG3 clrf MSGPTR ; put 'W' into message pointer MSG3_LOOP MOVF MSGPTR, W ; put the offset in 'W' CALL MSG3 ; returns ASCII character in 'W' ADDLW 0 ; sets the zero flag if W = 0 BTFSC STATUS, Z ; skip if zero bit not set RETURN ; finished if W = 0 CALL TransmitSerial ; output the character INCF MSGPTR, f ; point at next GOTO MSG3_LOOP ; more characters MSG3 ADDWF PCL,f ; offset added to PCL dt "AT+CPIN?",CR,0 ;------------------------------------------------------------------- ;Query network status ;------------------------------------------------------------------- OUTMSG4 clrf MSGPTR ; put 'W' into message pointer MSG4_LOOP MOVF MSGPTR, W ; put the offset in 'W' CALL MSG4 ; returns ASCII character in 'W' ADDLW 0 ; sets the zero flag if W = 0 BTFSC STATUS, Z ; skip if zero bit not set RETURN ; finished if W = 0 CALL TransmitSerial ; output the character INCF MSGPTR, f ; point at next GOTO MSG4_LOOP ; more characters MSG4 ADDWF PCL,f ; offset added to PCL dt "AT+CREG?",CR,0 ;--------------------------------------------------------------- ;Dial number ;--------------------------------------------------------------- OUTMSG5 clrf MSGPTR ; put 'W' into message pointer MSG5_LOOP MOVF MSGPTR, W ; put the offset in 'W' CALL MSG5 ; returns ASCII character in 'W' ADDLW 0 ; sets the zero flag if W = 0 BTFSC STATUS, Z ; skip if zero bit not set RETURN ; finished if W = 0 CALL TransmitSerial ; output the character INCF MSGPTR, f ; point at next GOTO MSG5_LOOP ; more characters MSG5 ADDWF PCL,f ; offset added to PCL dt "ATDT01424714790",CR,0 ;------------------------------------------------------------ OUTMSG6 clrf MSGPTR ; put 'W' into message pointer MSG6_LOOP MOVF MSGPTR, W ; put the offset in 'W' CALL MSG6 ; returns ASCII character in 'W' ADDLW 0 ; sets the zero flag if W = 0 BTFSC STATUS, Z ; skip if zero bit not set RETURN ; finished if W = 0 CALL TransmitSerial ; output the character INCF MSGPTR, f ; point at next GOTO MSG6_LOOP ; more characters MSG6 ADDWF PCL,f ; offset added to PCL dt "AT+CMGF=1",CR,0 ;------------------------------------------------------------ SCRATCH clrf MSGPTR ; put 'W' into message pointer SCRATCH_LOOP MOVF MSGPTR, W ; put the offset in 'W' CALL SCRATCH_MSG; returns ASCII character in 'W' ADDLW 0 ; sets the zero flag if W = 0 BTFSC STATUS, Z ; skip if zero bit not set RETURN ; finished if W = 0 CALL TransmitSerial ; output the character INCF MSGPTR, f ; point at next GOTO SCRATCH_LOOP ; more characters SCRATCH_MSG ADDWF PCL,f ; offset added to PCL dt "ATDT01424714790",CR,0 _Error: banksel PORTA bsf PORTA,LED goto _Error ;wait for RING wait_for_ring: call ClearBuffer banksel FSR movlw Buffer ;initialise buffer pointer movwf FSR aaa: call ReceiveSerialWait ;get char in W banksel INDF movwf INDF ;save in buffer movwf Temp banksel FSR incf FSR,F ;bump pointer movfw Buffer+2 ;'R'? movwf Temp movlw 'R' subwf Temp,w skpz goto aaa goto _Error dly: return movlw 0xFF movwf delay_counter1 dly0: movlw 0xFF movwf delay_counter2 dly1: decfsz delay_counter2,f goto dly1 decfsz delay_counter1,f goto dly0 return END▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Leon Heller
