Help with prop decision
I am wondering if anyone has used the ZX line of micro-controllers, link below.
http://www.zbasic.net/Microcontrollers/ZX-24x-Microcontroller/p-87.html
The reason i ask is i am hesitating on starting up using the prop because i am thinking a Basic language micro-controller, like the ZX, would be easier to come up to speed with.
However, as i read the amazing thinks that are being done with the Prop, i think whatever learning curve it takes will
be worth it in the end.
Can anyone chime in and give me an ideas as to your experience coming up to speed on the Prop as compared to a
Basic language micro.
cheers,
rich
cheers,
rich
Rich,
if you're just starting out, you might consider starting with the Basic Stamp. There are a number of great educationally-oriented kits available from Parallax. For comparisons, see: www.parallax.com/tabid/234/Default.aspx
Notice that you can even download their manuals as pdfs for free and take a look at how they walk you through what you need to know.
Once you get the hang of Stamps, then it's easy to move into the world of the Propeller. Of course, some people believe you can jump right into the Propeller without any problem, but if you're afraid to take too big of a leap all at once, then start with the Basic Stamp. It's all very easy and fun and people on the forums are very helpful so long as you do your homework and take things step by step.
I'm sure you'll enjoy it.
Alternately, you can use ZiCog or the other variants that emulate old Z80 computers and run CPM, MBasic, etc. See the ZiCog, TriBlade, RamBlade, DracBlade threads.
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
· Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
8x8 color 80 Column NTSC Text Object
Wondering how to set tile colors in the graphics_demo.spin?
Safety Tip: Life is as good as YOU think it is!
Like tune a DDS chip to a value, set a dac to a value, get some data from SPI or I2C or I2S.
The next step is standalone controllers for weather station, and data logging and when a terminal is hooked up and it get a commnad dumps the data already formatted.
Last is simple, autonomous robotics.
Those are the kind of things and i want to use the same Processor for all of it. I do not want to migrate after i invest in the learning curve.
Maybe idealistic but that's what i am thinking.
rich
You an dedicate separate COGs for inputs, one or more to do PWM (Pulse Width Modulation) for running steppers or other types of motors without expensive dedicated controllers, just a driver IC.
IN fact, I can't think of a single MCU that's better suited...
Should be good for a weatherstation, too.
Don't visit my new website...
The standalone controllers and robotics tasks would need to be done using either Spin, PropBasic, or C depending on what you're comfortable with. I'd recommend Spin (and some Prop assembly language eventually), but the others are viable choices.
When I want to do something, i often find an object or code on one of these parallax forums. Here is my run-down:
ZBasic microcontrollers - lots of power, full basic language, large programs, interrupts - limited support and miniscule community - high cost
Coridium microcontrollers - large program sizes, nice full featured basic interpreter with on-chip development environmetn - 3.3V, limited support (They do have nice development boards) - high cost
Basic Stamp - pretty basic basic, high cost - lots of support, hardware, books and program samples, nice development boards
SX microcontroller - Nice to use with SX/B, a bit harder than basic stamps to use, tricky variables, interrupts - really cheap - end-of-life but big supply still left
Propeller - super powerful, cheap, video capability, lots of support and large object library, object oriented, multiprocessing eases tasks. SPIN doesn't natively support strings (but does support arrays) though there are a couple good SPIN-based string libraries out there.
Of course, there are PICAXE, Arduino (C like) and full-dev ARM/ATMEL set ups too.
Personally, I started with Stamps, then went to coridium (played with ZBasic too), like the coridium because it was like using an 8-bit computer, then when to SX and SX/B because it was a lot cheaper and finally am trying things on the prop and love the COGs and multiprocessing.
If I were you, I'd give the Prop and one of the string libraries in OBEX a try. Let us know what you end up trying!
Tom Talbot
New Market, MD, USA
Tom Talbot
New Market, MD, USA
