Position of a shaft — Parallax Forums
Position of a shaft
FredBlaisFredBlais Posts: 380
edited 2010-07-31 04:59 in Robotics
Hi, is there any way to know the angle of position of a motor shaft with reasonable to high precision? The motor is not supposed do a full rotation, so I was doubting that rotary encoder or quadrature would be optimal, or maybe it is?
I thought about adding a potentiometer, but I want to avoid the added friction.
  • John AbshierJohn Abshier Posts: 1,116
    edited 2010-07-30 20:54
    Anything will have some friction. U.S. Digital (and others) sell absolute encoders that output the position of a shaft. A potetionmeter or quadrature encoder would also work. For the quadrature encoder you will need to figure out a way to get absolute position at power on. Turning the shaft until you trip a limit switch could work. There are aslo quadrature encoders with an extra index output that would work.
    John Abshier
  • FredBlaisFredBlais Posts: 380
    Hey thanks, the miniature absolute magnetic shaft encoder from US Digital was exactly what I was looking for!
