What is different about counters?
lardom
I normally can control transistors with an i/o pin and a pull-down resistor. When I tried to use one of the prop's counters for PWM I had to connect the emitter to propeller ground before the transistor would work. I guess that means the counters have lower signal voltage. I know there is something I don't see yet but I would like someone to help me understand why I had to use a propeller ground before I could switch on a transistor with a counter signal. Thanks
