Propeller external crystal help please?
Hello all,
I've recently built my 2nd programming board for the Prop, with the goal of being more flexible than the last. And so, I've built it so that an external crystal can be inserted/removed via a 3-pin female pcb connector (2 pins tied together going to one of the osc inputs, and the other single going to the 2nd osc input). I have some questions about this setup, though... and remember, I don't know much of anything about using crystals haha
1) Will the connector and solder joints between the external crystal and prop significantly change the frequency of the crystal as the prop sees it?
2) What is an "acceptable" distance from the prop for the crystal to be, under my described circumstances?
3) What is, most likely, the fastest "low-speed" crystal I can connect to the prop programmed to run with PLL16X?
All help is appreciated! [noparse]:)[/noparse]
- Robofreak
Austin Bowen,
"One must watch out for mechanics. They start out with a sewing machine, and end up with the atomic bomb" - A quote from someone that I saw on Addall.com
"Not only do I see the glass as half empty, I wonder if anyone poisoned the glass with arsenic" - My dad, inside joke haha
- Robofreak
Austin Bowen,
I'm no crystal expert but I'd bet you'll be okay with your socket.
Have you used a Prop Proto Board?· It has a crystal socket on the board so you can exchange crystals.· (I think the Demo board also has the sockets, but I loaned mine out so I can't check.· The Pro.·Dev. Board also uses the sockets.)
There was mention of where to buy the sockets on the forum.· You could try an advanced search through Google and try to find it.
I've read several times that traces to the crystal should be kept short, but I don't know specifics.
Duane
Leon Heller
Amateur radio callsign: G1HSM
Austin Bowen,
Leon Heller
Post Edited (Leon) : 7/31/2010 2:04:49 AM GMT
Austin Bowen,
