Visual Spin: Alpha2(b) release! — Parallax Forums
RaymanRayman Posts: 16,458
edited 2010-08-02 15:45 in Propeller 1
Visual Spin actually generates working code now!
It can even program the Prop directly.
You don't need propellent.dll or even have the Prop tool installed.
I still need to add more form objects (just buttons and text right now).
Also, I need to make some custom bitmaps for Visual Spin's buttons.
I'd be very appreciative if there's some brave people out there who want to test it.
Note:· Visual Spin currently assumes you are using the same VGA, mouse, and keyboard pins as the "Demo" and "Proto" boards use.
You can download it here:
http://www.rayslogic.com/propeller/Programming/VisualSpin/VisualSpin.htm
Here's a screenshot where I'm trying out different colors:
My Prop Apps:· http://www.rayslogic.com/propeller/Programming/Programming.htm
My Prop Info: ·http://www.rayslogic.com/propeller/propeller.htm
My Prop Products:· http://www.rayslogic.com/Propeller/Products/Products.htm
Post Edited (Rayman) : 7/30/2010 7:43:27 PM GMT
1559 x 1097 - 137K
