storing data in RAM
Hey y'all,
I just need a little clarity on storing data in EEPROM.
Here's a little sample code that I've tested - and it works.
The only problem - I think - is the location where the data is stored in the eeprom. It must conflict with the code.
I say that after pasting parts of this code into another program I'm running.
The other program runs perfectly fine until I store data in the eeprom.
The value I have for the variable eepromaddress is 0, or can it be $0000 - $7FFF? In any case there's a conflict.
If you have any suggestions then by gosh I'm all ears.
Shmow
Sample code below:
Shmow
Sample code below:
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
SCL = 28
StoreData = 255 'VALUE TO BE STORED IN EEPROM
eepromaddress = 0
VAR
byte buffer[noparse][[/noparse]32]
byte retrievedData
OBJ
i2c : "Minimal_I2C_Driver"
sio : "FullDuplexSerialPlus"
PUB Main
sio.start(31,30,0,115200)
i2c.initialize(SCL)
' i2c.readit
dira[noparse][[/noparse]16..17]~~
' INDICATOR LIGHT TO SHOW PROGRAM WILL START IN 4 SECONDS
' GIVES ME TIME TO OPEN PARALLAX SERIAL TERMINAL
outa[noparse][[/noparse]17]~~
waitcnt(clkfreq*4+cnt)
repeat
' WHEN BUTTON IS PRESSED, VALUE OF 255 IS STORED IN EEPROM
if ina[noparse][[/noparse]0] == 1
StoreVal
waitcnt(clkfreq*3+cnt)
else
' WHEN BUTTON IS NOT PRESSED, RETRIEVED DATA IS DISPLAYED ON PST (PARALLAX SERIAL TERMINAL)
RetrieveVal
PRI StoreVal
buffer[noparse][[/noparse]eepromAddress // 32] := 255
writeIt
PRI RetrieveVal
' VARIABLE IS ASSIGNED VALUE AT BUFFER LOCATION 32
readit
retrievedData := buffer[noparse][[/noparse]eepromAddress // 32]
' SHOW DATA ON P SERIAL TERMINAL
sio.dec(retrievedData)
sio.Str(string(13," ",13,13))
waitcnt(clkfreq+cnt)
PRI readIt
if i2c.ReadPage(i2c#BootPin, i2c#EEPROM, eepromAddress, @buffer, 32)
abort ' an error occurred during the read
PRI writeIt | startTime
if i2c.WritePage(i2c#BootPin, i2c#EEPROM, eepromAddress, @buffer, 32)
abort ' an error occured during the write
startTime := cnt ' prepare to check for a timeout
repeat while i2c.WriteWait(i2c#BootPin, i2c#EEPROM, eepromAddress)
if cnt - startTime > clkfreq / 10
abort ' waited more than a 1/10 second for the write to finish
Yes, you program is messing up the program stored in EEPROM.
