Does 6.25Mhz xtal need special timing? — Parallax Forums
soshimososhimo Posts: 215
edited 2010-07-29 14:35 in Propeller 1
I just got a couple of these bad boys. I hear it's possible to "overclock" the propeller with these. Do I need special timing with any of the time critical objects such as full duplex, spi, etc?
TIA
    edited 2010-07-29 04:32
    Most time critical objects use CLKFREQ to compute timing values and, if you set the clock constants (like _CLKFREQ or _XINFREQ) properly, the timing will all work out correctly. A few time critical drivers (like some video drivers) are intended to be used with an 80MHz system clock and will have problems with 96MHz or 100MHz or 104MHz unless some other constants in the code are changed. FullDuplexSerial should work fine and the SPI and I2C drivers should be timing independent.
  • KyeKye Posts: 2,200
    edited 2010-07-29 14:27
    Video drivers just need greater than or equal to 80Mhz.
    Nyamekye,
    ...except for the Parallax drivers, which will operate down to 64. AiGeneric will operate below 80, as will my older 8x8 drivers.
    8x8 color 80 Column NTSC Text Object
    Wondering how to set tile colors in the graphics_demo.spin?
    Safety Tip: Life is as good as YOU think it is!
