Easy, not necessarily cheap, PCB fabrication for beginners
Greetings, I have never tried a "PCB fab house" yet and i want to give it a go, only thing is, i haven't a clue where to start. I have looked around a little, but i haven't done a great deal of searching. I just need a couple of simple boards to test out.·2 layer is fine and it will be mostly thru-hole components. And right now i am not to concerned about cost.·I want to eventually start my own small·electronics·business and i know that good pcbs/ knowledge·are crucial. So·to the point.·From your collective experience, what is the best( And by best i mean ease of use, for now) PCB manufacturer for short runs?
Propeller + Picaxe = Romeo & Juliet
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
They provide free layout software and, though I had never made a pcb in my life, I was able to get up and running within a few hours. I've never tried anything else, so I can't compare, but if you consider that you don't really have to invest any money in the software, then it's a great way to get a feel for the whole concept of making pcbs.
Just my 0.0002 cents worth.
DipTrace has a free version of their PCB Layout software, I have found it very easy to use. Nick from Gadget Gangster has made a series of tutorials for it.
Rich H
There are a few steps from design to PCB so I wrote it up a few years back www.instructables.com/id/Professional-PCBs-almost-cheaper-than-making-them-/
(I've improved my board design skills a bit since then - eg thin tracks for data, fat tracks for power, moving device labels around on the board so they don't overlay each other).
Design a schematic. Design the board. Turn it into a Gerber (I've got quicker at that - I can make a gerber/drill file in less than 30 seconds now). Send an email to OurPCB with a zip attached. Quote comes back about 6 hours later. Send money with Paypal. Receive boards about 10 days later.
Sometimes I get an email back with a question "did you really want to put these two components on top of each other?" and I correct my silly mistake and send a new zip.
It is all pretty easy. So easy in fact that I am very reluctant to do point to point wiring nowadays.
www.smarthome.viviti.com/propeller
I've used Eagle Cad and a company in mainland China that accepts payment by USA PayPal and delivers in a few weeks. I had shopped a lot of places before doing so - Sparkfun and Futurelec seemed to come closest in price.
The two weeks extended to four as we had some communications problems, but the people were very careful to deliver good product. Delays were because we both didn't understand the files I gave them, but Eagle Cad gave us the answers.
Of course if you want to do this all at home, Eagle Cad will print transparencies on an HP Inkget (other brands don't work as the ink beads up). And then photo expose the board, remove the excess, and etch with ferric chloride. That inkjet transparency doesn't completely dry, so be sure to not smear the ink when handling.
That still leaves you to find your prefect way to drill holes. And you likely have made a rather limited one-sided board. I cut the board down to size with a hack saw (nice fine teeth) and drill all the holes by hand with a small drill held in a pin vise (a hand tool made for such purposes). Usually, I drill holes while having my morning latte at Starbucks and reading the newspaper. It goes rather quick and I don't have all the control problems of power drills. (bit breakage, skidding across the board, and so on).
Ain't gadetry a wonderful thing?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
I would only be producing one offs and would likely use the laser printer toner transfer technique. Does the layout software share a common format, or are you locked into one? I've heard people mention Gerber files which sound like a common PCB format, but I've seen design files specify particular programs. So that sounds like you are locked in.
All reputable software will export a gerber.
Leon Heller
Amateur radio callsign: G1HSM
Olimex offers 2 board size options, 1 or 2 layers.
On the other hand they depanelize for free.
Massimo
Leon Heller
Also, if you go with advanced circuits, put in referral for Phil or W9GFO so they can get the $25 outback restaurant gift certificate!
Tom Talbot
New Market, MD, USA
Leon Heller
Now I use Sunstone Circuits . They have good pricing for mass production and lots of options, but lately I have been using them for single board or up to 10 board runs, they are great because you can get small single-run circuit boards that are custom shaped, masked, and silked which ExpressPCB does not do for single boards. And it is about the same price, if not a little cheaper. They have a CAD program to work with their system (called PCBExpress -- geez, people need to get creative), but they accept gerber files from any software.
Don't get sucked in to ExpressPCB, use PCBExpress, or DipTrace or Eagle!
April, 2008: when I discovered the answers to all my micro-computational-botherations!
Some of my objects:
MCP3X0X ADC Driver - Programmable Schmitt inputs, frequency reading, and more!
Simple Propeller-based Database - Making life easier and more readable for all your EEPROM storage needs.
String Manipulation Library - Don't allow strings to be the bane of the Propeller, bend them to your will!
Fast Inter-Propeller Comm - Fast communication between two propellers (1.37MB/s @100MHz)!
high quality boards, no complaints.
Online quotes
Email the Gerber and drill plot file
Pay with Paypal.
Wait 10 days.
Affordable and many options on board size, thickness, routing, pannelization etc ...
Searider
Their website has some video tutorials (no audio). Those got me started, it is quite easy to learn compared to other programs (like Eagle), but not to say it is easy. If you have never used and type of CAD before, that alone is a big learning curve, but the actual program is fairly easy.
Some of my objects:
Some of my objects:
DipTrace on the other hand could give you a completed board with only a few clicks, but that is assuming you don't care about interference issues or other potential electrical issues. Manual part placement wikl look cleaner usually and take up less space. The auto routing works pretty good, just route important low impedance traces first. And there is all the error checking you will even need in DipTrace.
Some of my objects:
Some of my objects:
