Propeller in a car...
Hi all,
I would like to had some features to my car and I'm planning to use a propeller for that.
What I want to add is:
If I found other ideas, I will probably at it [noparse];)[/noparse]
My question now is regarding the power suply. I found 12V in the dash and I want to power my board with that. I need to get 5V (The display) and 3.3V from this 12V.
Can I use an LM317 for that? 12V will be enought. But will it be to much and that will overheat? Also, when I start the car, is there some risk to burn the LM317 and/or the prop?
Is there anything I should worrie about with a project like this one?
JM
- Temperature controller (instead of just an on/off fan with warm air);
- OGG (Or mp3 if not available) player;
- Rear alarm (the thing which beep when your bumper is close to the wall);
- RTC with multiple alarms, countdown;
- A display and some buttons to control all of that.
JM
Otherwise you need to dissipate the heat generated. The higher it input voltage, the more power goes to heat on the regulator.
For instance in my case a LCD with back light was too much.
A switching regulator works fine with me..
What I'm expecting to use is:
A LCD back ligh screen http://www.parallax.com/Store/Accessories/Displays/tabid/159/CategoryID/34/List/0/SortField/0/Level/a/ProductID/51/Default.aspx- 2 or 3 Digital Thermometer http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/DS1620/List/0/SortField/4/ProductID/84/Default.aspx
- A Breakout Board for VS1053 http://www.sparkfun.com/commerce/product_info.php?products_id=8954
- A card reader
- And maybe a ping.
So you said the screen was too much, which mean it will be the same issue for me.
What do you mean by "A switching regulator"?
JM
Linux? There is worst, but it's more expensive.
So heat to be dissipated is proportional to voltage drop and current. The protoboard dissipates heat on the pcb. If you add in your design a heat sink it could be enough and happily live with the linear regulator.
Swhitching regulators are (in general) a more efficient solution.
For instance I use linear's LM2594. You need more external components.
Check the net. The manufacturers usually have designer's guides available for free.
For instance:
focus.ti.com/lit/an/slva118/slva118.pdf
Massimo
www.onsemi.com/pub_link/Collateral/HB206-D.PDF
Massimo
Based on my knowledge with electronic components, I will probably go with a heat sink first [noparse];)[/noparse]
And thanks a lot for the links! I will start to read the 1 document you sent. I might be able to get something from that.
JM
Have fun!
Massimo
www.seetron.com/an_vpwr1.htm
JM
They are a switching powersupply that will be much better than a linear one. It has a fixed 5V and an adjustable one.
I'd bypass the linear ones on the proto board and drive it and what ever else you need from this. It will deliver upto 1amp on each the 5V and the adjustable one. I'd replace the pot with a fixed resistor.
Jim Fouch
FOUCH SOFTWARE
I will see what's the best option for my needs.
Thanks again.
JM
