Video on the Propeller
········· I am using the VGA_Text.spin, and I have some monitors that will not show any video. I have 4 different propeller boards. If I shoot video out of 2 different propeller demo boards, it seems to work on any monitor. If I shoot video out of the propeller proto board or my own board, it does not work on all monitors. I can get it to work if I shoot the video out of the propeller proto board, and run that through a KVM unit. It then runs on all 4 boards and on all monitors.
········ Do I have some kind of a termination type problem. I copied the video layout of the propeller demo board. I did not include the LED's and their 240ohm resistors. Could this be a problem? Can I add additional resistors on my board to get past this.
········· What can I do to my board so that all monitors work from it?
thanks so much,
Don
thanks so much,
Don
In terms of resistor values, look at the Protoboard + Accessories Kit schematic.· It shows the proper resistor values for VGA·without the LEDs and their resistors.
······· Mike, you seem to know a lot about video. Is there another hi res solution, other than this VGA_text.spin, that only uses 1 cog for video? I am starting a project and it isn't to late to change this yet.
······· Thanks so much
Don
It will be released in the Obex soon but I havn't got arround to it.
Nyamekye,
I will take a look at it tonight. The 3D tiles code look interesting.
Thanks so much,
Don
