I need a discrete, voltage-independent, current limiting circuit
I am looking for a (simple as possible) voltage-independent, current limiting circuit, preferably a schematic of discrete components, but I may be able to manage with an IC or two.
Any suggestions would be great, I can't seem to find anything just by googling it, so I am hoping someone knows a circuit, or where to find it.
April, 2008: when I discovered the answers to all my micro-computational-botherations!
Some of my objects:
MCP3X0X ADC Driver - Programmable Schmitt inputs, frequency reading, and more!
Simple Propeller-based Database - Making life easier and more readable for all your EEPROM storage needs.
String Manipulation Library - Don't allow strings to be the bane of the Propeller, bend them to your will!
Fast Inter-Propeller Comm - Fast communication between two propellers (1.37MB/s @100MHz)!
Some of my objects:
http://www.ametherm.com/inrush-current/inrush-current-faq.html
http://www.radio-electronics.com/info/circuits/transistor_current_limiter/transistor_current_limiter.php
I used a single transistor to limit charging NiCad packs to 1/10th of the maH rating. You might find more about doing so in NiCad charge schematics.
Ain't gadetry a wonderful thing?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
Leon Heller
Amateur radio callsign: G1HSM
Some of my objects:
See http://diyaudioprojects.com/Technical/Voltage-Regulator/·at the bottom for a current regulator:·a LM317,·a cap·and·a resistor. Doesn't get much simpler than that.
Post Edited (erco) : 7/26/2010 9:59:20 PM GMT
I don't understand why the window is limited in that way. If the input signals are voltages that turn the transistor on and off, the acceptable window with an appropriate resistor in place sould be much larger, easily 1.5 to 7V.
A current limiting diode may be the part you are looking for.
Tracy Allen
www.emesystems.com
These won't work all the way down to zero volts without quite a bit of additional circuitry. It has something to do with the 'diode drop' involved. To get to zero, I suspect you need a negative power source as well as positive. But you should easily be able to go up to 30 or so volts.
