Speed Controller on a RC car Nube question
I have· Traxxis RC Car with a speed controller.
I know i can control the steering servo and transmission servo.
Can the BS control the speed control?
If so what signalsdo the speed controller need?
While you're working on it, put a BUNCH of fail safes in there..... like run the control signal though a pushbutton, and/or disconnect the power to the wheels through a big toggle switch and make a fixture to hold the car securely with the wheels elevated. Ya don't want the car to go flying off your bench when you flip on BS power!!
"puff"...... Smile, there went another one.
thanks
john
- Stephen
The Futaba timings define "neutral" or "no activation" to be 1522 uSeconds. Widths less than this amount are considered to be a "reverse" command, widths greater than this amount are considered to be "forward" commands. A dead zone of 20 uSeconds is defined to exist around neutral, such that any pulse that is within 10uS of neutral (wider or narrower) shall be considered to be equivalent to a neutral pulse. This specification insures that small variations in the output signal around neutral do not cause motor activation or "jitter."
The relationship between the input and the motor activation is shown below in figure 1.
Figure 1: Relationship of Pulse Input to Motor Activation
The system uses 16 forward and 16 reverse speeds, created by a activating the H-bridge for n 16ths of a period. When n is 0 the motor is not activated at all, when n is 16 the motor is continually activated.· The base PWM frequency is determined primarily by sample clock (1Khz) divided by 16 time slots, or a base frequency of 62.5 Hz. This frequency may be increased however be aware that around 325 Hz it will interfere with Futaba PCM receivers.
If you go on Parallax website, find the servos they sell and download the sample code, that will be everything you need. You'll have to tweak the timing numbers a bit for an ESC, but it's all there.
