Lowpass for Video Output? — Parallax Forums
Christoph_HChristoph_H Posts: 31
edited 2010-07-26 17:50 in Propeller 1
Hi everyone,
a friend of mine could use a simple test pattern generator for troubleshooting CCTV installations and I volunteered to help him. The software is based on ericball's PAL_colorbars.spin (thanks by the way, if you're reading this). I've taken a look at the video signal of the first prototype on my oscilloscope and compared it to a few other devices in reach.
Because of the way the propeller is generating the video signal, the higher harmonics of the color sub carrier are quite large compared to the background noise. Those CCTV installations also incorporate RF links where cable runs aren't feasible and I'm worrying that the high frequency components of the video signal might cause trouble in these transmitters. So I'm thinking about adding a passive lowpass filter between the DAC and video output connector.
I've simulated a 5th-order Butterworth with a corner frequency of 8MHz in pspice and the results look good to me - the 3rd harmonic is already quite a few db attenuated and the group delay up to the colorburst frequency is not so bad.
What are your thoughts on this?
    edited 2010-07-25 16:37
    There should be no harm in that. You will have to buffer the filtered signal to restore the 75-ohm output impedance. Also, be aware that the unfiltered output impedance from the typical Prop video circuit is not 75 ohms, but more like 150. Without a load it will produce 3V P-P, rather than 2V.
    A simpler approach might be to output the chroma separately and filter it with a crystal lattice filter at the colorburst frequency. The crystals required for this are very easy to get. Then recombine the chroma and luma/sync signals.
    So try one of these options, see if it works, and report back here with your findings. This is something a lot of folks might benefit from.
  • LeonLeon Posts: 7,620
    edited 2010-07-25 18:14
    The Butterworth filter is nice and flat, but you get phase delays that might cause problems.
    Leon Heller
    Amateur radio callsign: G1HSM
    edited 2010-07-25 19:27
    The phase delays may not be an issue, so long as they're consistent among all the scan lines and between the colorburst and the chroma signals within a line. If this is not the case, you will get shifts in hue, or else the color could disappear entirely if the phase changed between lines.
    edited 2010-07-26 07:34
    I think that using a xtal latice filter would be far too high a Q factor to allow the "usual" chroma bandwidth (up to 1MHz) even on simple bars.
    The signal is not that fantastic (ie "Broadcast Quality") so a simple filter should be ok. I looked around, here at work, for an analog vector 'scope to have a look at my home made Demoboard's output but I cannot find one, they are all SDI. There is a "scrap yard" over in our other unit so I will go and see if I could scrounge one.
    There was a cct diagram that gave a closer approximation to 75 Ohms a while back, it used a more complicated cct in component count, and non standard values, but should present itself to a filter more kindly.
    Why did I think a new, more challenging, job was a good idea ??
  • Christoph_HChristoph_H Posts: 31
    edited 2010-07-26 08:47
    Phil, Leon, Toby: Thank your for your advice.
    While my current prototype DAC uses the resistor values from the demoboard schematic, I had already planned to follow phil's suggestion for a better 75Ohm match from another thread. I haven't even thought about using the Y/C mode and recombining the signals later, so that's an interesting proposal. Although, as Toby mentioned, the crystal filter would probably have a too narrow passband. The filter I have in my mind will modify the output impedance (see attachments), so an highspeed opamp buffer would certainly be the right way to do this but if it's possible I'd like to avoid the opamp.
    I don't think I'll encounter any problems with the phase of the signal; as I understand it it would be nice to have linear phase at the frequencies of interest and at least up to the color frequency the deviation is quite small.
    This project is indeed not in any way meant to generate a broadcast quality signal (although the clock will be at 4.43... MHz to avoid PLL jitter) and I fully understand that it's not possible to get the SMPTE color bars because of the amplitude and hue restrictions. I'm just trying to filter the output signal so it's not too revolting to any connected device. [noparse];)[/noparse]
    The attachments show the 5th order butterworth, component values were computed with www-users.cs.york.ac.uk/~fisher/lcfilter/ and rounded to the nearest value I can get for a reasonable price. The series resistance of the inductors is also modeled although this will not make much of a change. The second image should show the amplitude response and the third one the phase response (with a linear scale). The last one is the impedance as seen by the 75Ohm source if the filter is also terminated with 75Ohm.
    762 x 164 - 3K
    1012 x 607 - 8K
    1012 x 607 - 13K
    995 x 607 - 9K
    edited 2010-07-26 13:49
    Christoph_H
    I was intrigued by you saying that you were using the 4.43MHz clock to avoid jitters. I tried that a long time back and the video wouldn't run at all, the objects say that 80MHz is a minimum and so I just stopped playing. I was trying to improve the background colour beating that I was getting from my homebrew DemoBoard, at a nominal 5MHz PLLx16. Using a 6MHz rock seemed better and so I experimented with some 4.43 and a 8.86 ones but got nowhere. I have since found that the declaration of the Freq can be tweaked a bit and yeilds better pics. mostly it was 4_999_500 to get the best ie least patterning.
    edited 2010-07-26 14:55
    I'm currently using the PAL version from the first post of this thread, but thinking about writing my own implementation, just for the fun of it. The 4.43M crystals will be in the next order from my distributor, so I can't say yet if they'll really fix the image artifacts I'm seeing here. In ericball's driver there isn't any limitation that would prevent using it at 4.43M*16 - I've taken a closer look at the main loop and I seem to remember that this isn't even close. In fact the prototype is running at only 7.3728M*8 so the correct crystal should work alright.
    By the way - at first I had a 5M crystal connected and hadn't thought that I'd better change the PLL factor after exchanging it for the 7.3.. one. I must have been running at over 117MHz and there were no signs of malfunctions. [noparse]:)[/noparse]
    I have played with the frequency declaration a bit when I was using a prop for the first time, more than a year ago, but couldn't get the TV_Text_Demo to run without diagonal stripes.
    edited 2010-07-26 15:09
    The stripes are not "got rid of" with the Freq tweak, they just don't make themselves as obvious. I also wish to have a portable signal source/measuring box for cable and monitor proving. I will have to get around to it. I tried LFT's Phasor (AVR)to see is it would be suitable for bending down to just bars. The signal would lock colour on a glass monitor but few LCDs seemed to like it much. I have a comercial (Teletest) box but I would like an audio, composite/YC and VGA combo box, perhaps the 2 x 16 LCD could be used for crude level indications too.
    edited 2010-07-26 15:11
    Toby,
    You're right about the crystal lattice filter having too high a Q. I hadn't thought about that. The rapid phase shifts for hue would never make it through.
    I've also seen cases where adjusting _xinfreq slightly can improve video quality. This has to be done on a case-by-case basis, though, to accommodate slightly different crystal frequencies. It may also be the case that crystal aging or changes in temperature could render such fine tweaking ineffective over the long run.
    edited 2010-07-26 15:14
    Those templates will run with a fairly low clock. If a large waitvid frame is used, the clock can be considerably lower than 80Mhz. That's the limiting factor on the clock.
    The only thing needed for various clocks, is to compute the PLLA value. (PLLA/CLKFREQ) * (2^32) gets that done.
    IMHO, the Parallax graphics object should work too. The minimum for that one is 64Mhz, I believe. The only tweak potentially required would be to lower the resolution on the TV cog. Don't know whether or not the default configuration shipped with the Prop tool was tested that low, but it could be adjusted.
    Another one that works pretty low is the one pin TV Eric wrote. It can clock way down --and I think he actually got it working on as little as 20Mhz, maybe 12! I don't recall exactly. At that clock, it was good for a few characters per line. Something like 40 pixels of resolution.
    The newer drivers I've been working on run at lower clocks too. Potatotext at 20 or maybe, maybe 32 characters per line will operate on less than 80Mhz. All that's needed is to do the PLLA calculation and edit the value for your particular board. Running color requires more, monochrome less clock.
    8x8 color 80 Column NTSC Text Object
    Wondering how to set tile colors in the graphics_demo.spin?
    Safety Tip: Life is as good as YOU think it is!
  • ericballericball Posts: 774
    Christoph_H said...
    You're welcome. Using the 4.43MHz crystal should help with the phase jitter. (Just be sure to cycle count any WAITVID to WAITVID times. I found the front porch timing tight sometimes.) However, I'd recommend developing your test patterns first before you get too into tweaking the output with filters etc. You may find you can get by with a lower order filter, or maybe something which has nulls at the worst harmonics. Plus coding (even with my templates) will probably be time consuming, or you may find the Propeller's output capabilities are too limited for the task.
    Composite NTSC sprite driver: Forum
    NTSC & PAL driver templates: ObEx Forum
    OnePinTVText driver: ObEx Forum
