Compiler Benchmarks — Parallax Forums
Compiler Benchmarks
Dave HeinDave Hein Posts: 6,347
edited 2010-09-15 14:14 in Propeller 1
Compiler benchmarks are being discussed in another thread, so I thought I would start up a new thread about it.· A simple "Hello World" benchmark was proposed to determine the executable size of a small program.· The source for this benchmark is
#include <stdio.h>
void main(void)
    printf("Hello World\n");
I compiled this with CSPIN 0.060 and CLIB 1.0.1 using BST.· The resulting size was 4,336 bytes.· Anybody care to try the other C compilers?· It would also be interesting to get results for Spin and PropBASIC versions of this benchmark.
Note: Very small versions of this program could be hand crafted to produce 100 or 200 bytes.· The goal is to determine the size of the program with the normal development environment.
Post Edited (Dave Hein) : 7/25/2010 1:33:55 AM GMT
«134
  • jazzedjazzed Posts: 11,803
    edited 2010-07-25 01:44
    Did you have BST unused code trimming enabled? A C compiler would not include unused module code.
    Propeller Pages: Propeller JVM
    edited 2010-07-25 01:54
    Yes, I set all of the optimization on BST.· The problem is that printf calls vfprintf, which uses vsprintf and fputs.· vsprintf calls various string functions, including the float-to-string functions.· fputs uses malloc to create a file handle, and so on.· I would expect that most C compilers will have the same issue with pulling in lots of functions that aren't really required.
  • RossHRossH Posts: 5,779
    edited 2010-07-25 02:33
    @Dave,
    I presume you're talking about final binary size, and not just code segment size? Out of the box, with no optimization, Catalina's closest equivalent to what your CSPIN program does produces a binary file of 7576 bytes.
    However, while this appears to support my contention that LMM programs could end up taking 2 times (or less) of the equivalent byte code program size, I should say I don't think this is a true comparison. The problem is that neither program is 'genuine' since neither one is using a real version of stdio. If we were to insist on only comparing programs that do that, then Catalina can do so (so can ICC) but CSPIN cannot.
    If I instead compile this program to use a true ANSI C standard 'stdio' instead of a reduced functionality version it generates a binary of about 13k - but only about 6k of this is actual program and library code (the rest is initialization of the kernel and the various drivers). But before you say 'of course this must be included' I should also add that if I use Catalina's EMM loader, that means this program really does only use only 6k of the Propeller's 32k hub RAM at run time, leaving 26k for more program code.
    My point is that it's not easy to come up with a simple comparison that actually means anything.
    Ross.
    edited 2010-07-25 02:54
    Ross, yes I am referring to the binary size.· I do realize that there are a lot of variables that make it hard to do a comparison.· An extremely simple implementation of the printf function that was essentially just puts would not take many bytes at all.· I coded up the Spin version of this using FDS and·it used 552 bytes.· I suspect most of that was the FDS PASM program.
    I think the main point of the "Hello World" benchmark is just to get an idea of the size of a minimal program using printf.
  • BeanBean Posts: 8,129
    edited 2010-07-25 02:58
    This program...
    DEVICE P8X32A, XTAL1, PLL16X
    FREQ 80_000_000
    TX   PIN 31 HIGH
    PROGRAM Start
    Start:
      SEROUT TX, T115200, "Hello World"
    END
    which I assume does the same as your C program. Is 33 LONGS according to BST, it generates the follow code:
    ''  *** COMPILED WITH PropBasic VERSION 00.01.02  Jul 20, 2010 ***
    CON                                                          'DEVICE P8X32A, XTAL1, PLL16X
      _ClkMode = XTAL1 + PLL16X
      _XInFreq =   5000000                                       'FREQ 80_000_000
    ' TX   PIN 31 HIGH                                           'TX   PIN 31 HIGH
    PUB __Program                                                'PROGRAM Start
      CogInit(0, @__Init, @__DATASTART)
    DAT
                      org           0
    __Init
    __RAM
                      mov           dira,__InitDirA
                      mov           outa,__InitOutA
                      jmp           #Start
    Start                                                        'Start:
                      mov           __temp1,TX                   '  SEROUT TX, T115200, "Hello World"
                      mov           __temp5,par
    __L0001
                      rdbyte        __temp2,__temp5 WZ
                      adds          __temp5,#1
        IF_Z          jmp           #__L0002
                      or            __temp2,#256
                      shl           __temp2,#1
                      mov           __temp3,#10
                      mov           __temp4,_115200baud
                      add           __temp4,cnt
                      or            dira,__temp1
    __L0003
                      shr           __temp2,#1 WC
                      muxc          outa,__temp1
                      waitcnt       __temp4,_115200baud
                      djnz          __temp3,#__L0003
                      jmp           #__L0001
    __L0002
                      mov           __temp1,#0                   'END
                      waitpne       __temp1,__temp1
    __InitDirA       LONG %10000000_00000000_00000000_00000000
    __InitOutA       LONG %10000000_00000000_00000000_00000000
    TX               LONG 1 << 31
    _115200baud      LONG 694
    _FREQ            LONG 80000000
    __remainder
    __temp1          RES 1
    __temp2          RES 1
    __temp3          RES 1
    __temp4          RES 1
    __temp5          RES 1
    __param1         RES 1
    __param2         RES 1
    __param3         RES 1
    __param4         RES 1
    __paramcnt       RES 1
    FIT 492
    CON
      LSBFIRST                         = 0
      MSBFIRST                         = 1
      MSBPRE                           = 0
      LSBPRE                           = 1
      MSBPOST                          = 2
      LSBPOST                          = 3
      InLineStr1_ofs                   = 0
    DAT
    __DATASTART
    InLineStr1
                     BYTE "Hello World",0
    Use BASIC on the Propeller with the speed of assembly language.
    PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
    March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
    NEW PropBasic Blog: http://propbasic.blogspot.com
    There are two rules in life:
    · 1) Never divulge all information
    If you choose not to decide, you still have made a choice. [noparse][[/noparse]RUSH - Freewill]
    Post Edited (Bean) : 7/25/2010 3:34:29 AM GMT
  • Kevin WoodKevin Wood Posts: 1,266
    edited 2010-07-25 03:24
    Bean, it looks like you need to add a CR after "Hello World" (\n = newline)
    edited 2010-07-25 03:26
    @Bean,
    Very nice! But you are also not comparing apples with apples since your program does not use 'printf' (or anything even vaguely equivalent). Also, you are using a serial device, whereas Dave and I are including a general purpose local display driver (at least I think Dave's example does - my example certainly does). I can reduce my binary size by a couple of kilobytes just by using a simpler serial I/O driver instead.
    This just highlights the problem. All we are doing in this thread is comparing the 'minumum' initial program footprint of various approaches, not the actual program size. However, I'm not complaining - this is exactly what the simple 'hello world' type benchmarks are typically used for. On this basis, I would expect Catalina's minumum footprint to be larger than most others. Does it matter? Not in the slightest!
    Ross.
    edited 2010-07-25 03:36
    Yeah, there really isn't anything like printf in PropBasic. So the "benchmark" is pretty meaningless.
    I just thought I'd throw it out there because Dave brought up PropBasic.
    Just for the record, the same program as LMM uses 75 instructions total. (I'm pretty sure I heard that all the C compilers generate some kind of LMM. Yes ???)
    P.S. Oh yeah, I forgot the CR.
    Bean
    edited 2010-07-25 03:41
    Ross, it matters. You're just in denial.
    It's probably more meaningful to find the smallest solution that does nothing except print Hello World.
    No FDS, no floating point, no filesystem. It would be easier to understand that way and not too off topic.
    I value the convenience and power of C printf especially in larger programs where it makes a difference.
    edited 2010-07-25 04:04
    @jazzed,
    It matters about as much as it ever did when people used to do this kind of comparison of various languages or compilers on a PC. Someone would always jump in with a perl or python script (or a lisp, forth or basic program) and claim that their 'program size' was only 20 bytes whereas a compiled C program was more like 20 kilobytes.
    It didn't mean anything then, and it doesn't mean anything now. I'm happy to have these results posted but most people will realize they don't measure anything meaningful smile.gif
    Ross.
    edited 2010-07-25 05:28
    Size matters with limited memory. For you to insist that size does not matter is silly. Many things I want to do with Propeller are constrained by the inescapable fact that memory is limited. I work on bigger memory solutions to keep my Propeller options open and LMM C, ZOG, Propeller JVM, perhaps others, and even Spin with constraints make bigger programs possible with added external resources. If you don't want bigger EEPROM or external memory, the best solution for size is Spin/PASM: that's why I almost never bother with C on Propeller now. I am hoping that will change soon though.
    edited 2010-07-25 08:14
    @jazzed,
    Either you are simply intent on misconstruing what I am saying, or you really don't understand. Assuming the latter, I will try and explain it one last time.
    All I have said (several times) is that I now expect LMM programs to be around twice the size of byte code programs - perhaps even slightly less with a good optimizing compiler. I used to say 'between two and four times', but my opinion on this has recently changed as I have now had the chance to compare some actual examples of byte codes generated by Dave's CSPIN compiler with LMM code generated by Catalina. This is discussed in the Catalina thread, with examples. I'm not claiming all the evidence is 'in' yet, but no-one has yet offered much evidence to the contrary, so I think my claim is prefectly reasonable - at least until we have the opportunity to do a true comparison by compiling exactly the same C code with both an LMM C compiler and a byte-code C compiler.
    However, for some reason you continually try to intepret this as me claiming that 'size does not matter'. I'm not sure why you insist on this, but I think I may have at least managed to track down the comment to which you may be referring:
    rossh said...
    Finally, does size really matter? You can buy 'another manufacturer's' micro with as little as 0.5k of RAM - and people routinely program such micros in C, even when they only run at a few Mhz. So even if programming the Propeller in LMM C takes betwen 2 and 4 times as much RAM as programming in byte coded C, and is between 2 and 4 times slower [than assembly language], we should still be able to accomodate programs written in C that would require between 8kb and 16kb in 'another manufacturer's' chips - even if their assembly language were as efficient as a byte code (which is unlikely).
    I think that comment is perfectly reasonable - some people insist on worrying exactly how much C code you can fit onto a Propeller, when the people we need to be attracting to the Propeller probably couldn't care less - if the Propeller offers C it will be used by them where it is cost effective to do so. If the propeller doesn't offer C (or offers only a non-standard version of it) it will not be used at all. This is the sense in which size does not really matter.
    Can you see the difference?
    Getting back to the subject of this thread, I don't think anyone would seriously claim 'hello world' as a decent method of comparing code size unless both compilers also use the same C library functions and they were also programmed in C - otherwise you are effectively trying to compare the relative code sizes by looking at a single line of code that makes a single function call, with a single parameter. How sensible is that?
    However, 'hello world' can be a decent method of assessing 'minimal program footprint' - but only if you also insist that all programs use at least 'functionaly equivalent' libraries and drivers - otherwise it is not even useful for that - which is why it's more commonly regarded with amusement than as a serious benchmark (see stackoverflow.com/questions/284797/hello-world-in-less-than-20-bytes).
    Ross.
    edited 2010-07-25 11:02
    3456 bytes in BDS C on the Propeller running CP/M or MP/M.
    Minor change to the syntax "void main()" instead of "void main(void)"
    384 bytes in SBASIC.
    39 bytes (hex=27) in Z80 Assembly on the Propeller
     00001                .Z80
     00002      0100        ORG 0100H
     00003
     00004 0100 C3 0112     START:    JP MAIN
     00005
     00006      0005    FDOS    EQU    0005H    ; COMMON ENTRY POINT FOR BIOS AND BDOS
     00007
     00008 0103 48 65 6C 6C TEST_TEXT:        DB    'Hello World$'
     00009 010F 0D 0A 24    CRLF:            DB    13,10,'$'
     00010            ; ************************************************
     00011
     00012            MAIN:
     00013 0112 11 0103         LD DE,TEST_TEXT
     00014 0115 CD 0119         CALL WRITE_STRING_CR
     00015 0118 C9            RET        ; back to cp/m
     00016
     00017            WRITE_STRING_CR:
     00018 0119 0E 09        LD C,9
     00019 011B CD 0005         CALL FDOS
     00020 011E 11 010F         LD DE,CRLF
     00021 0121 0E 09        LD C,9
     00022 0123 CD 0005         CALL FDOS
     00023 0126 C9            RET
     00024
     00025 0127            END
    Of course, size does not really matter. I'm off to buy my red sports car now...
    www.smarthome.viviti.com/propeller
    Post Edited (Dr_Acula) : 7/25/2010 12:26:21 PM GMT
  • heaterheater Posts: 3,370
    edited 2010-07-25 11:44
    Zog is big.
    11944 bytes using "printf".
    16952 using "iprintf" - integer only printf
    16944 using "siprintf" - Not sure what's different about this one.
    3228 using "print" - Unformatted printing of strings.
    That last result is nice. All of them could be shrunk by 1K my removing the ZPU EMULATE instructions jump table which Zog does not use.
    Not sure why Zogs integer only printf is actual less compact than the standard printf.
    I'm surprised that Zog actually beats BDS C. Not really a useful comparison, BDS C is using 16 bit ints on an 8 bit machine. Zog is all 32 bit. Doing 32 bit maths on BDS C might me expected to produce bigger code than Zog.
    P.S. Compiling a statically liked and stripped hello world binary for my Linux box results in an executable size of 511384 bytes!!!
    Post Edited (heater) : 7/25/2010 11:55:27 AM GMT
    edited 2010-07-25 12:14
    22 bytes for a spinix script "program".
    #she
    echo Hello World
    It helps when the OS does all the work.
    Dave
    Post Edited (Dave Hein) : 7/25/2010 12:21:53 PM GMT
    edited 2010-07-25 12:15
    @heater,
    That '511384' number can't be right. I just tried it using gcc under Windows - 11,264 bytes.
    Did you use 'strip' on the executable? Without that, the Windows executable comes in at a whopping 1,116,958 bytes!
    Ross.
    edited 2010-07-25 12:17
    @Dave,
    Ross.
    edited 2010-07-25 12:39
    Yikes Ross, over a megabyte to print Hello World? I wrote an entire practice management program in vb6 for just under a megabyte. Bloatware is alive and well. No wonder one of my work computers took 20 minutes to start today.
    Darn it, Dave sets a high standard here with 22 bytes.
    Ok - some little cheats. CP/M accepts CR as a CRLF so only need to send the 13, not the 10.
    Don't call a bios function then RET to CP/M. Jump to the bios function and the RET at the end will RET to CP/M.
    Tested on a real propeller board:
    1A>HELLO
    Hello World
    1A>
     00006 0100 11 0108         LD DE,TEST_TEXT
     00007 0103 0E 09        LD C,9
     00008 0105 C3 0005         JP FDOS        ; the fdos RET will return to CP/M
     00009
     00010
     00011      0005    FDOS    EQU    0005H    ; COMMON ENTRY POINT FOR BIOS AND BDOS
     00012
     00013 0108 48 65 6C 6C TEST_TEXT:        DB    'Hello World',13,'$'
     00014
     00015 0115            END
    3 bytes for LD DE, Test_text
    2 bytes for LD C,9
    3 bytes for JP FDOS
    11 bytes for Hello World
    1 byte for the CR
    1 byte for the $ symbol (CP/M uses this instead of ascii 0 for end of string)
    The END is just a marker, not part of the program.
    Total 21 bytes.
    edited 2010-07-25 13:34
    RossH: Oh yes.
    $ rm hello
    $ cat hello.c
    #include <stdio.h>
    int main(int argc, char* argv[noparse][[/noparse]])
            printf("Hello world.\n");
            return(0);
    $ gcc --static -o hello -Os -Wall hello.c
    $ wc -c  hello
    574245 hello
    $ strip  hello
    $ wc -c  hello
    511384 hello
    gcc --version
    gcc (Debian 4.4.4-7) 4.4.4
    All this on my Debian testing installation. On Debian stable it is much the same. What on earth is going on?
    edited 2010-07-25 13:57
    Wow heater. Never seen anything like that before.
    steve@steve-laptop:~$ mkdir csource
    steve@steve-laptop:~$ cd csource
    steve@steve-laptop:~/csource$ cat > hello.c
    #include <stdio.h>
    int main(int argc, char** argv) {
       return 0;
    steve@steve-laptop:~/csource$ ls
    hello.c
    steve@steve-laptop:~/csource$ gcc -o hello hello.c
    steve@steve-laptop:~/csource$ ls -l
    total 12
    -rwxr-xr-x 1 steve steve 7139 2010-07-25 06:55 hello
    -rw-r--r-- 1 steve steve   96 2010-07-25 06:55 hello.c
    steve@steve-laptop:~/csource$ ./hello
    Hello World
    edited 2010-07-25 14:25
    Jazzed: My hello program was compiled with the --static switch so that no dynamic libs are used. All the code goes into the executable. Which is how programs are often built for small systems with no operating system to handle dynamic lib loading.
    If I compile as you did, with dynamic libs, I get 4511 bytes. Then stripping the symbols out it is 2868.
    Post Edited (heater) : 7/25/2010 2:32:54 PM GMT
    edited 2010-07-25 14:42
    heater said...
    This explains a lot of that 0.5MB.
    steve@steve-laptop:~/csource$ ls -l /usr/lib/gcc/i486-linux-gnu/4.4.3/../../../../lib/libc.a
    -rw-r--r-- 1 root root 3031076 2010-06-14 07:35 /usr/lib/gcc/i486-linux-gnu/4.4.3/../../../../lib/libc.a
    COLLECT_GCC_OPTIONS='-v' '-static' '-o' 'hello' '-mtune=generic' '-march=i486'
     as -V -Qy -o /tmp/ccOi7TRp.o /tmp/ccfpwaGX.s
    GNU assembler version 2.20.1 (i486-linux-gnu) using BFD version (GNU Binutils for Ubuntu) 2.20.1-system.20100303
    COMPILER_PATH=/usr/lib/gcc/i486-linux-gnu/4.4.3/:/usr/lib/gcc/i486-linux-gnu/4.4.3/:/usr/lib/gcc/i486-linux-gnu/:/usr/lib/gcc/i486-linux-gnu/4.4.3/:/usr/lib/gcc/i486-linux-gnu/:/usr/lib/gcc/i486-linux-gnu/4.4.3/:/usr/lib/gcc/i486-linux-gnu/
    LIBRARY_PATH=/usr/lib/gcc/i486-linux-gnu/4.4.3/:/usr/lib/gcc/i486-linux-gnu/4.4.3/:/usr/lib/gcc/i486-linux-gnu/4.4.3/../../../../lib/:/lib/../lib/:/usr/lib/../lib/:/usr/lib/gcc/i486-linux-gnu/4.4.3/../../../:/lib/:/usr/lib/:/usr/lib/i486-linux-gnu/
     /usr/lib/gcc/i486-linux-gnu/4.4.3/collect2 --build-id -m elf_i386 --hash-style=both -static -o hello -z relro /usr/lib/gcc/i486-linux-gnu/4.4.3/../../../../lib/crt1.o /usr/lib/gcc/i486-linux-gnu/4.4.3/../../../../lib/crti.o /usr/lib/gcc/i486-linux-gnu/4.4.3/crtbeginT.o -L/usr/lib/gcc/i486-linux-gnu/4.4.3 -L/usr/lib/gcc/i486-linux-gnu/4.4.3 -L/usr/lib/gcc/i486-linux-gnu/4.4.3/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/i486-linux-gnu/4.4.3/../../.. -L/usr/lib/i486-linux-gnu /tmp/ccOi7TRp.o --start-group [b]-lgcc -lgcc_eh -lc[/b] --end-group /usr/lib/gcc/i486-linux-gnu/4.4.3/crtend.o /usr/lib/gcc/i486-linux-gnu/4.4.3/../../../../lib/crtn.o
    Post Edited (jazzed) : 7/25/2010 3:34:43 PM GMT
    edited 2010-07-25 15:11
    How about we find some more normal codes for this benchmarking?
    As we see here the hello world is not much good for this task. It does not have any code in it to speak of and all the work is done by the OS or libraries which are very dependent on libraries. Also it shows us a one time overhead of all the printf stuff, including malloc etc. If you print two strings the program does not get twice as big.
    Further I would say that for a lot of embedded work things like printf are not even required.
    Dhrystone has been mentioned but as it is heavily biased toward string operations I don't see it as being representative of a lot of embedded code either.
    As a start I'd like to propose the xxtea encryption algorithm.
    It's a nice small self contained function with a good selection of if, while, for. It uses 32 bit arithmetic, arrays and a hand full of nice operators.
    As a bonus it may even be useful to have around. We could wrap it in a loop and do some timing measurements as well.
    Attached is a version of xxtea as found on wikipedia. It's only called once from main to decrypt a message. There is no output from this program unless PRINTING is defined when compiling it, then it uses printf.
    For GCC the Zog/ZPU binary is 3592 bytes with no printing and 12392 with.
    The actual btea function itself is 369, which I think is the important number to look at.
    edited 2010-07-25 18:19
    heater,
    The xxtea code is fine for a benchmark.· Could you also measure the number of cycles it takes to execute the function?· I'll port it to CSPIN and determine the size and speed as well.
    I would also like to do a comparision using Dhrystones.· I was able to get it to compile under CSPIN with some modifications.· CSPIN doesn't support enums or 2 dimensional arrays yet, so I had to make some changes.· Ross, I know you will object to changing the source code, so the numbers I measure with CSPIN will need to be treated as unofficial preliminary values until I get enum and 2D arrays implemented.
    Dave
    edited 2010-07-25 23:04
    @All,
    Here are the raw numbers for xxtea for Catalina:
    No printing: 4808 bytes
    Printing: 12684 bytes (includes stdio printf and drivers)
    btea: 1092 bytes (273 long instructions)
    cycles: 268720
    UPDATED: cycles added.
    edited 2010-07-26 00:15
    These xxtea results provide good details. Thanks for continuing the efforts.
    edited 2010-07-26 08:58
    RossH, Damn, there goes Zog's supposed advantage in code size. He only uses byte wide ops rather than LONG instructions but of course there are many more of them.
    In this case Zog is only about 20% smaller. Also I had a look at the byte codes and found GCC is sneaking in calls to some library code. To handle unsigned divides I think. So I should really include that function as well. The 20% advantages then disappears[noparse]:([/noparse]
    I have to find a new benchmark that only uses signed ints [noparse]:)[/noparse]
    edited 2010-07-26 11:42
    @heater,
    Don't panic! - I was calculating the size of btea in hex, not decimal - now corrected.
    So Zog is comfortably smaller.
    Ross.
    edited 2010-07-26 12:13
    You mean Catalina code is three times bigger in this case. Perhaps only two if I include that hidden div function that zog includes.
    Wow, that may just cheer me up enough to continue with Zog[noparse]:)[/noparse]
    You forgot to update the last line of that post:
    s/Seems quite comparable with Zog./Zog beats Catalina hands down./
    edited 2010-07-26 12:24
    @heater,
    I knew something wasn't right there. Serves me right for doing it in a hurry.
    Update your stats when you figure out how big the library routines Zog uses actually are.
    Ross.
