Understanding Signals with the PropScope - Chapter 2: DC Measurements (Draft Copy)
Andy Lindsay (Parallax)
Get the Latest Full Textbook in Print or PDF
The latest version of Understanding Signals with the PropScope is now published in both print and PDF.
You can download the full PDF textbook from:
www.parallax.com/go/PropScope
Thanks to all our reviewers for their input!
John Abshier
Shouldn't the CH1 wire be in the Vdd connector, and the CH2 wire in the Vin connector? And the little schematic adjusted to reflect those connections?
And on p. 49 near the bottom you have "In brief, a potentiometer has a resistive element that spans it’s A and B terminals".
That should be "...that spans its A and B terminals" (no·apostrophe on "its").
On p. 50 near the top, you have "The sum of these to resistances will always add up to the resistance between A and B"
That should, of course, be "of these two resistances".
P. 51 - the box reads "Another Option: Connect ground clips to the plated holes at the corners of Your board. Like the Vss sockets, the metal in the plated holes at the each corner of your board are also connected to your board’s negative power terminal, so they are also Vss connections."
Might this be a good place to point out that many boards like the Propeller Professional Development Board have built-in ground connections for oscilloscope use?
P. 52 - "A BASIC Stamp I/O pin set to input interprets voltages above 1.4 V as binary-1 and below 1.4 V as binary-0."
That might be slightly less confusing with the hyphens removed ("as binary 1 and...as binary 0"), as they could be interpreted as minus signs.
(See my comment on the Ch 4 draft: apparently the document is inconsisent in how these are labeled. A standard is needed).
P. 53 - The box includes this "and the resulting current the I/O pin would try to supply the circuit trying to pull the 0 V ground connection up to 5 V would quickly damage the I/O pin."
How about this instead? "and the resulting current would quickly damage the I/O pin, as the the pin would try to supply current to pull the 0 V ground connection up to 5 V".
Post Edited (sylvie369) : 7/28/2010 6:26:16 PM GMT
This is great material! Thank you. All has been duly noted and queued for the next edit. I should have the Chapter 5 draft up tonight. After that, I'll be taking a 1 week break, and will resume posting chapters 6-9 starting either Thursday, 8/5 or Friday, 8/6.
Andy
Andy Lindsay
Education Department
